Gateways
Mad4radio
Gateways
Post by Mad4radio » 15 Jun 2015, 15:27
Ok with links from scotland to sheffield to st Ives to bradford the server has been running fine & dandy via teamspeak for 5month or so, So here we go we've decided to open it up abit more for anyone else wishing to add they gateway to the few more that are already on the system at present running on teamspeak for wider communications, Ok granted it ticks all the boxes for those in RF blackspots as it brings activity via the gateway but to some its cheating...... FRN's fine but it lags teamspeak on the other hand as it happens works brilliant & works in full duplex mode as well, So here it is if you have a gateway or have a feed & want to bring a little more activity via your gateway or have a feed you want to share drop me a pm & if your interested & we'll allocate you a channel/slot on the TS server...........
TRON
Re: Gateways
Post by TRON » 15 Aug 2015, 22:43
What's your server details?? I'm going to be setting back up soon.
Mad4radio
Re: Gateways
Post by Mad4radio » 24 Aug 2015, 08:45
Send us a PM tron
TRON
Re: Gateways
Post by TRON » 24 Aug 2015, 16:38
I just looked again, and you're using teamspeak, and that means VOX. I broke my old interface up for parts seeing as it wasn't getting used. The only interface I have right now is COM port so would only work with FRN and similar programs that use com port keying.
Actually.. hold on a minute... Doesn't teamspeak have a plugin now that allows com port keying?
AshtonMobileScanner
Call Sign: 26TM931
Re: Gateways
Post by AshtonMobileScanner » 24 Aug 2015, 23:32
Hey Colin any idea why im banned from the server permantly as ive not done anything to get banned for?
Motorola UHF DP3600 x2,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
CALLSIGN: 26 TM 931 / 26 CT 931
AshtonMobileScanner
Call Sign: 26TM931
Re: Gateways
Post by AshtonMobileScanner » 31 Aug 2015, 19:38
Ive sent a PM, Its been read but no reply :(
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
AshtonMobileScanner
Call Sign: 26TM931
Re: Gateways
Post by AshtonMobileScanner » 11 Sep 2015, 02:56
Anybody joining the server just be careful not to get banned, me and my partner got banned from the teamspeak server for nothing. Ive tried contacting Colin for a reason why we have been banned and just blatantly get ignored.
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
AshtonMobileScanner
Call Sign: 26TM931
Re: Gateways
Post by AshtonMobileScanner » 14 Sep 2015, 19:38
The problem has been solved now lol, everybody was banned by accident when the server had a few problems. Im back in the server soon :)
Cheers Colin lad :D
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
