FRN Gateway in Swanley Kent since Feb 2012
- New User
- Call Sign: MPT061
Hi all.
I have had a gateway up & running since feb this year, PMR chnl 8 tone code 20, ( ctcss 131.8 ). But not many users so far, It has a very good take off point & good range. Its connected to FRN english users when on line,,,,,,,,,,,,,,,Also I have a Parrot Repeater that goes in use when frn feed is quite, The Parrot is on pmr chnl 8 & open, ( no codes ).
So Give it a go if you are in the Area,,,,,,,,,,,
TTFN,,,,,,,,,,,,,,,QRT.
- Guzzy
- Call Sign: 26TM002
Re: FRN Gateway in Swanley Kent since Feb 2012
Wow, that must make you popular with any random person who just happens to try to use channel 8.The Parrot is on pmr chnl 8 & open, ( no codes )
- MrWeetabix
- Admin
- Call Sign: 26TM175
....sorry, parrot reply kicking in
- Guzzy
and every time some one keys up........sorry, parrot reply kicking inMrWeetabix wrote:....sorry, parrot reply kicking in
- Guzzy
keys up ...
- Guzzy
keys up ...
- Guzzy
- Guzzy
Guzzy wrote:Argh ....
- New User
- Call Sign: MPT061
Around this area there is not much pmr use, The Kids love the parrot repeater & use it when on, It increases there radio range, ie, from home, to the stables & playing fields.
- Call Sign: M6JXP
I expect most of them don't have a clue WTF is going on
- Steve152
Seems the Swanley gateway has moved to channel 6 ctss 20 heard it very strong while on the m25 dartford yesterday tried to call in but it was v busy ,great to hear it that busy.
well done john
well done john
26 TM 152
- Call Sign: FRANCISUK22
Yeap
It has moved to CH6 CTCSS 131.8
Also there is a gateway on CB UK Band 29 located Clapton on sea Essex
Now: TYT UVF1, Baofeng UV-5R, Baofeng BF-888s
Previously: Binatone Terrain 550, Alan HP450
Scanners: ICOM IC-R5 with MRW-210 Super Gainer Antenna - Grecom PSR-282
