The speakermike connections on the KG-UVD1 are normal Kenwood type - same as the Puxings.
The aerial socket is also the usual Chinese type - takes an SMA-F aerial.
Wouxun KG-UVD1P... grrrr
- Yeti
Re: Wouxun KG-UVD1P... grrrr
- bigbloke
that said, there are some variants of puxing progging leads that work with the UDV1-P , and some that dont
Specific Wouxun "KG" series leads all seem to work a1 first time.
so there is something different in the lead config, but Ive never pulled two apart to compare.
theyre cheap enough though !!
Regards
BB
Regards
BB
I should be getting my KG-UVD1P this week and have ordered a USB programming cable but don't think it is coming with any programming software. Do any of you have a link to download the programming software?
Cheers,
Richard
Cheers,
Richard
- bigbloke
directly from http://www.wouxun.cn when I last looked . click the ENGLISH link in the top right corner
actually this link should take you straight there:
http://www.wouxun.com/DownView.asp?ID=2&SortID=4
regards
BB
regards
BB
- dcwuk
I bought mine from 409shop and yes the psu went up in smoke the wallwart started to smoke.
emailed 409 and they sent me a replacement wallwart and base no problem at all
The original base turned out to be OK so it was only the psu that had failed
- New User
Hi all,
I am interested i buying a pair of KG-UVD1P. I head that some Wouxun had porblem operating while the temperature was low (radio refusing to work altogether). Does anyone know if the latest UVD1P does suffer from similar problems? I plan to use mine for outdoor activities...
Cheers,
/jmc
Cheers,
/jmc
