maxon sl25
- tippohat
maxon sl25
Just got these two radios, they are "Maxon sl25-u2-6", it also says "EASIWAVE" on the inside. They have 6 channels.
Got these today from my dad, he said he didnt know where he got them from but they dont have a charger. Does anyone know anything about these radios? Any information would be appreciated. I know absolutly nothing about them. If they are decent enough I will probably invest in a charger.
Cheers.
Cheers.
Remember there are no stupid questions, just stupid people.
- iansradios
Re: maxon sl25
Lower powered maxons on srbr or uk gen yet i have seen these on a pmr shopwatch for some strange reason, old radios now but try garex for info on them. leaflet http://www.murphy-com-hire.com/maxon/maxon-SL25.pdf
- tippohat
Re: maxon sl25
Did I post this in the correct area?
I might just buy a charger for them because they are bound to be better than the tecnika pmr radios I bought before, they sucked really badly.
- iansradios
Re: maxon sl25
Its a pmr so you should be ok,anything is better than what you were using,although some people may frown on here with you using high power radios on a bad that you shouldnt but i say let hime is without sin cast the first stone,we all know the rules find me someone that has stuck to them
- tippohat
Re: maxon sl25
Are they illegal to use then? I remember reading somewhere that pmr needs to have a non detatchable antenna?
They only have 6 channels, would they be the first 6 pmr channels?
- Guzzy
- Call Sign: 26TM002
Re: maxon sl25
They're "PMR" and not "PMR446"
PMR covers all the 'commercial' (read privately licensed) frequencies.
PMR446 is specifically the eight (or 16 digital) licence free "PMR446" frequencies.
The Maxon SL25's are probably programmed up on commercial frequencies and therefore (at least legally) you can only use them if you have a UKGL or private 'commercial' PMR licence.
Even if you got them re-programmed for the eight "PMR446" frequencies, they would still be illegal to use as they are not 'type certified' for PMR446 (they output too much power).
Does anyone care, would anyone notice?
Probably not.
... but don't walk up to an Ofcom official and rub their nose in it.
Probably not.
Re: maxon sl25
Unless he's got the PMR446 version?
- Yeti
Re: maxon sl25
If it says Easiwave, my bet is they're on the old SRBR channels.
- marshphantom
Re: maxon sl25
yer they be old srbr freqs.
just opened up my software for the sl range of maxon radios and for these it will not get close enough to put these onto pmr446, i can have a 12.5, 20 or 25 step i can get close on some channels.
if you ever want the freqs changed drop me a message bud.
used to do the same for the icom f4sr, changing all those from the srbr freqs, but since they are not that used any more i never get asked to do it lol
Ed
Marsh Phantom
26-TM-1986 - 26-CT-112
Marsh Phantom
- Yeti
Re: maxon sl25
odd...marshphantom wrote:yer they be old srbr freqs.
http://www.wrekincom.com/easiwave-radio.htm
http://www.wrekincom.com/pmr446_sl25.htm
- iansradios
Re: maxon sl25
I went to look at a problem radio on the shopwatch that was an sl25,they just couldnt hit the rptr but could hear alright.
- marshphantom
Re: maxon sl25
Yeti wrote:odd...marshphantom wrote:yer they be old srbr freqs.
My mistake yeti, i was opening the old version of the software not the newer (even that is 3 years old lol)
the old version was writen to not allow onto the 446 i remember now.
sorry i have been on the road all day, but it is do able, and i am happy to do it if you have these radios kicking about.
Ed
Marsh Phantom
Marsh Phantom
Re: maxon sl25
I had some Maxon's the easiway freq's ARE illegal now they were withdrawn some time ago and replaced with 449Mhz and 446
easiwave lived around 461 Mhz and were quite low power
I used to strugle to get a few hundered yards out of them,
449 on full power is much better
10.10
10.10
