Tait T2000
scottyboy
Tait T2000
Post by scottyboy » 26 Oct 2017, 12:04
I posted a question in the computer control software section but will ask here also In case it catches someone that section misses.
I have purchased a lot of Tait t2000 mk1 and mk2. (T2010)
All have the data board fitted and I have programmed some up but no tx, only rx is possible.
All were used on data systems (autocab and Auriga)
I have read that the data board needs reset? Shorting 2 pins?
1 option was to remove the data boards but if possible I would like to leave them in for selling purposes.
Any advice would be appreciated.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
tbftb
Re: Tait T2000
Post by tbftb » 09 Dec 2017, 01:45
Have you got this sorted yet?
26mb04
Call Sign: 26MB04
Re: Tait T2000
Post by 26mb04 » 10 Dec 2017, 17:55
You need to know if they're Data radios or voice ones. If they're data ones, you're probably only able to get around 10 channels by messing with the trunking software. There are a LOT of T2000 data radios going around for this reason.... If they're voice, you should be OK. The reset procedure I followed for the 1st gen voice radios was this:
1: Crack the top lid off, and find the eprom chip with the battery module on top of it. Remove it completely from the board and remember which way it goes on;
2: Power up the radio. The radio should make some weird noises for a few minutes, leave it on....
3: When the weird noises level out after a few mins, turn the radio off and plug the eprom back in again THE RIGHT WAY AROUND;
4: Reprogram the radio using the correct software. I don't think V2 software will work on a V1 radio etc. V1 software is DOS and a pain to run through, especially if you want to fill it with 200+channels etc.
I haven't done this for a while, it worked for me on a V1 voice radio but I've no idea if it works on a trunking board. But they were cheap, right? ;)
5-YR LEGAL AM/SSB NET: 27 JUN 19 1700 - 2200Z
AM CALL 27125 (CH 14) USB CALL 27275 (CH 27)
thelad
Re: Tait T2000
Post by thelad » 10 Dec 2017, 22:07
If they are ex bus ones the will be trunking ones.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
scottyboy
Re: Tait T2000
Post by scottyboy » 29 Dec 2017, 20:18
Sorry for the delay in replying.
They all are T2010 4 channel radios.
Vhf band ex taxi radios 136-174mhz
Conventional operation and not Trunking.
All that was known by me at time of purchase.
I now have sorted it out and converting them back to normal 2 way voice operation, tested on a local 2m repeater and working good.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
26mb04
Call Sign: 26MB04
Re: Tait T2000
Post by 26mb04 » 29 Dec 2017, 23:21
Glad you get them working. If you can find the correct head unit and memory board, you CAN convert them to a 200ch rig. The head unit and board need to match that gen of radio though... You can also swap the band boards over (bottom side) and change a 2m into 70cm, 4m, etc, but it'd probably be easier and cheaper to just buy the correct rig in the first place.
scottyboy
Re: Tait T2000
Post by scottyboy » 01 Jan 2018, 19:17
Yea for the price it’s probably not worth it. But thanks anyway for the tip.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
tby
Call Sign: EI7FO
Re: Tait T2000
Post by tby » 17 Feb 2018, 16:33
Any chance you could post the mod ( or PM) to get them to TX, I have removed data boards from a few
and no Tx, Thanks
tby
Call Sign: EI7FO
Re: Tait T2000
Post by tby » 18 Feb 2018, 12:21
Can anyone confirm or otherwise the links in attached for T2000 work?
, the T8000 does.
26mb04
Call Sign: 26MB04
Re: Tait T2000
Post by 26mb04 » 15 Jun 2018, 00:44
I don't know, I'm not familiar with that addon board. It's probably worth messing around with though, especially if it gives you a sq logic level, etc.
