TYT MD380 squelch...what ?
WhiteNoisePoetry
Post by WhiteNoisePoetry » 19 Mar 2016, 10:13
Just noticed that the MD380 I have in my hands only has two squelch settings - normal and tight.
All very well, but what are the levels and how can they be controlled ?
Can't see nowt in the software yet.
73 de WNP
Re: TYT MD380 squelch...what ?
Post by Admiral » 19 Mar 2016, 19:06
You can use the 'buttons definitions' to program a function button to toggle between normal and tight, I can't tell the difference so far.
WhiteNoisePoetry
Post by WhiteNoisePoetry » 20 Mar 2016, 08:08
Admiral wrote:You can use the 'buttons definitions' to program a function button to toggle between normal and tight, I can't tell the difference so far.
I wonder what the actual levels are (-dbm) ?
Never seen a radio with just two levels ;-)
73 de WNP
GeeFull
Post by GeeFull » 20 Mar 2016, 13:50
73 de WNP
There have over the years been some PMR based radio's that came with "local/dx" preset squelch threshold levels, usually on screen or button selected, as opposed to a continuously variable squelch threshold "pot".
The old Low VHF band Ascom 550, and its higher in frequency band derivatives being one example.
It sort of made them "none radio savvy", plug and play, idiot proof.
Not really sure who the TYT MD380 was aimed at?
WhiteNoisePoetry
Post by WhiteNoisePoetry » 20 Mar 2016, 21:15
Thanks Geeful.
73 de WNP
radiosification
Post by radiosification » 01 Apr 2016, 20:18
All the Motorola DMR equipment only has the two squelch levels too. The TYT is basically a copy of them!
Transmission1
Admin
Admin
Call Sign: 26TM001
Post by Transmission1 » 24 Aug 2016, 10:37
On side note about the MD380, I used mine on holiday recently and we used the radio in standard analog FM mode and it seems to be a very good performer, better than I expected. The squelch levels seemed about right and kept the radio silent between transmissions.
The only thing that annoys me slightly about the MD-380 is the scanning feature. I programmed one of the side keys to operate the scan function and it works fine but the radio shows the channel you have selected until it stops on an active channel, then it shows the name that you've programmed into the memory location. I know it shows a symbol on the display to indicate scanning but it would be nice if the display showed the channel changing as it scans. I'm guessing this is done to keep the scan rate higher as the processor in the radio has less to do when not driving the display.
Simon, 26TM001 - East Yorkshire, UK
Founder of Transmission1 & Tango Mike 26 Division Co-ordinator
http://www.tangomike.net/
Metradio
Call Sign: G7HID
Post by Metradio » 24 Aug 2016, 13:12
Bear in mind the squelch settings are only used in analogue mode...
Mike
bigbloke
Post by bigbloke » 24 Aug 2016, 20:55
Metradio wrote:Bear in mind the squelch settings are only used in analogue mode...
Mike
i can assure you , having had one on a dmr test set in the lab , that for DMR leave squelch to "normal".
its not greyed out in the CPS for a reason.
Regards
BB
troffasky
Post by troffasky » 24 Dec 2016, 13:37
Transmission1 wrote: The only thing that annoys me slightly about the MD-380 is the scanning feature. I programmed one of the side keys to operate the scan function and it works fine but the radio shows the channel you have selected until it stops on an active channel, then it shows the name that you've programmed into the memory location. I know it shows a symbol on the display to indicate scanning but it would be nice if the display showed the channel changing as it scans. I'm guessing this is done to keep the scan rate higher as the processor in the radio has less to do when not driving the display.
You could try the third-party firmware [if you haven't already] and post a feature request here if it doesn't do it: https://github.com/travisgoodspeed/md380tools/issues
radiosification
Post by radiosification » 26 Dec 2016, 23:23
I've never seen a commercial radio that could do that. I don't honestly see the point. There is an icon on the screen to show it's scanning. Showing the channels changing probably wastes battery and processor time as you said Troffasky. They already have lots of feature requests to deal with on the md380tools project.
