tytera announce forthcoming DMR mobile
Re: tytera announce forthcoming DMR mobile
Post by Admiral » 09 Jul 2017, 18:41
bigbloke
Post by bigbloke » 09 Jul 2017, 19:29
try mixing private calls with group calls
e.g.
regards
BB
Post by Admiral » 09 Jul 2017, 22:28
Okay, it did this:
bigbloke
Post by bigbloke » 11 Jul 2017, 13:19
now individually re-import the original channels CSV and the re-organised contacts CSV into the CPS and look at your channel data afterwards
(not the contacts list)
find the channel that had TG1 as the digital contact and you NOW have a contact of private call - RADIO-1 STEVE
oops ! you will never hear TG1 on that channel
This is because the digital contact name is not stored against a channel in the channel data CSV export file - its stored against its original position in the DIGITAL CONTACT "NO". column
And that's a coder's cluster**** !!
regards
BB
bigbloke
Post by bigbloke » 11 Jul 2017, 13:31
I suspect the same issue exists on the MD2017 / RT82
BK
Post by BK » 11 Jul 2017, 20:36
Just spotted an unboxing video on youtube
https://www.youtube.com/watch?v=yauK1AVP5Ag
Post by Admiral » 12 Jul 2017, 08:03
BK wrote:Just spotted an unboxing video on youtube
Aaaaaaagh, please tell me the DTMF mic is an option rather than standard, I'm sure it is great for pros, but I have no use for one and really don't like them, I'm forever sending loud tones to people on air because of my sausage fingers and arthritis.
bigbloke
Post by bigbloke » 12 Jul 2017, 09:41
Thanks for the link BK.
I hadnt seen that fan on the back before ! wont go where I was hoping to fit it
(VWT5 roof cubby hole) without a mod...have to be on the fusebox cover :-(
the only feature missing - and believe me I pestered TYT - is the ability to change your DMR ID from the front panel
or programme it on a per channel basis
hopefully Travis / Ty will hack and add this
regards
BB
Post by Admiral » 12 Jul 2017, 09:57
bigbloke wrote: the only feature missing - and believe me I pestered TYT - is the ability to change your DMR ID from the front panel
regards
BB
That would be a cool feature, that's why I have two UHF 380's, one for ham stuff and one for 'other' stuff. It's too much of a pain to swap the ID over every time, and sooner or later I would forget and it could be embarrassing to say the least.
bigbloke
Post by bigbloke » 12 Jul 2017, 10:46
Admiral wrote: Aaaaaaagh, please tell me the DTMF mic is an option rather than standard
sadly, no
regards
BB
bigbloke
Post by bigbloke » 12 Jul 2017, 10:49
Admiral wrote:That would be a cool feature, that's why I have two UHF 380's, one for ham stuff and one for 'other' stuff. It's too much of a pain to swap the ID over every time, and sooner or later I would forget and it could be embarrassing to say the least.
you do realise that both the travis goodspeed alternative firmware AND the Ty Weaver firmware (a derivative of Travis' work) for the MD380 both
support this natively ? They add a menu item to do it .
regards
BB
Post by Admiral » 12 Jul 2017, 10:54
I've had them a couple of years BB, twas before that firmware, I've actually got used to using two now.
Hopefully there is a software option, or an internal pot to adjust the low power on this set as 25w low power is too much for my liking.
bigbloke
Post by bigbloke » 12 Jul 2017, 11:12
Well theres 4 power settings ...and tyt tend to hide the test menu in their CPS
I just loaded the CPS & hit <ctrl><t> and it grumbled that the USB connection wasnt available so I imagine you
can set the 4 power levels in there.
Regards
BB
bigbloke
Post by bigbloke » 22 Jul 2017, 22:23
theres a guy on youtube just reviewed one of the samples ( hamradio 2.0 ) and his test confirm that the
low power settings run just under 5W
Regards
BB
BK
Post by BK » 24 Jul 2017, 16:23
bigbloke wrote:theres a guy on youtube just reviewed one of the samples ( hamradio 2.0 ) and his test confirm that the
Love this guy's approach to unboxing videos "It's out of the box - shut up!" :D :D :D
