tytera announce forthcoming DMR mobile
bigbloke
Re: tytera announce forthcoming DMR mobile
Post by bigbloke » 08 Jun 2017, 09:13
so for those that werent aware the prototype of the 9600 has now been videoed operating.
despite insistence from a TYT employee that it would be two models (VHF / UHF) I am pleased to confirm its dual band. its basically
an MD2017 in a new box with a bigger PA. encryption is also supposed to be compatible between all two slot (!) DMR radios
Regards
BB
bigbloke
Post by bigbloke » 07 Jul 2017, 18:48
its starting to get real !!
CPS for MD9600 posted to TYT website today !!
** UPDATE ** My AV has gone ballistic about this file - might be best to wait awhile
50 samples released to dealers - mass production starts at the end of the month
regards
BB
Post by Admiral » 07 Jul 2017, 19:10
Hmmmmmm.
bigbloke
Post by bigbloke » 07 Jul 2017, 22:13
64 channels per zone on the 9600
(im playing with the CPS in a virtual sandbox for safety)
enhanced key length / format seems to be the same as the MD380 (128 bit)
theres no option to set your DMR ID on a per channel basis so lets hope its made it into the on screen menu
or Ty Weaver adds it :-)
suggested retail price is 338 USD which equates to about 262 pounds in todays money
regards
BB
Post by Admiral » 07 Jul 2017, 22:23
Good thinking, I'll give it a whizz on Win7 via the Oracle virtual machine.
bigbloke
Post by bigbloke » 08 Jul 2017, 11:54
AVG have reviewed the file and passed it .
now running it on the main radio PC
regards
BB
Post by Admiral » 08 Jul 2017, 12:45
Well, apart from the enhanced zones and a 'VFO' option it all looks very familiar. I'm not too thrilled about stated Hi power 45w and Lo 25w, I would have preferred 45w and 5w myself, but the software has High, Middle, Middle Low, and Low, I wonder if Middle and Middle Low are between 25 and 45 or if the spec is different to that stated in the ads????
bigbloke
Post by bigbloke » 09 Jul 2017, 12:45
some nice options in this CPS
* It can load MD380 codeplugs as though they were native to the MD9600
* you can import and export both contacts and channels list so they can be edited in excel or a text editor
(tested with excel 2007 - worked flawlessly) this is VERY powerful
* It also supports DCDM (2 slot simplex) as either master or mobile station.
DEFINITELY buying one ! :-)
regards
BB
bigbloke
Post by bigbloke » 09 Jul 2017, 14:59
one EPIC fail in the software
a zone can support 64 channels, but a scanlist can only support 31 still
so if you were hoping to use this as a marine scanner , you can get all the public channels in one zone, but you cannot
scan them .
I've mentioned it to TYT
Regards
BB
BK
Post by BK » 09 Jul 2017, 15:54
bigbloke wrote:* you can import and export both contacts and channels list so they can be edited in excel
Oh, I like that - I'd much rather write a codeplug in excel instead of the CPS.
Post by Admiral » 09 Jul 2017, 16:31
I presume it would be in CSV format?
bigbloke
Post by bigbloke » 09 Jul 2017, 16:43
yes CSV format
BUT theres a MAJOR flaw
Contacts in the channels list on CSV export are persisted on a POSITION IN DIGITAL CONTACTS TABLE BASIS
The contacts export DOES NOT REFERENCE THIS TABLE
so whereas in your nice list of CSVs you have :
Code: Select all
Contact Name,Call Type,	Call ID,Call Receive Tone
In the channel detail you have the position of the user in the list and not the identity of the user
So if you were to sort your contacts, by name, alphabetically, in say excel for nice and easy reading then you re-import them
then you BREAK the relationship with your contact and its position in the list - effectively every digital channel has have its contact re-aligned
manually - YEEEEUCH !!! :-( :-(
What WERE they thinking ???
regards
BB
(still digging his was through the CPS)
BK
Post by BK » 09 Jul 2017, 16:48
bigbloke wrote:In the channel detail you have the position of the user in the list and not the identity of the user
manually
Not ideal, but could you combine the lists so they are side by side in a single sheet, and then split them into separate sheets again when you're finished?
bigbloke
Post by bigbloke » 09 Jul 2017, 17:27
Theoretically maybe - practically it would be a ruddy nightmare - you'd need an excel macro to fix it externally - the contacts list export file has no position index in it to cross correlate , you would need to screen grab from the digital contacts list in the CPS or create an index manually in excel post export then use the macro to re-edit the channels data spreadsheet. recipe for disaster
the channel data spreadsheet is 51 columns wide !!
regards
BB
Post by Admiral » 09 Jul 2017, 18:41
I'm probably being a bit thick here, but I put in some random names, exported, put the names in A-Z order in Excel, re-imported and the names are now in A-Z order in the contact list with the correct TG associated, isn't that how it should be?
goto next message down on page 3
