Hi currently playing about with some dp3400 and cps software.
I have a dp3400 which when i try to read it,says codeplug password.I dont know it.
Can i go to 'recover a device' to get programming access to the radio? I was wishing to read it so i could program another radio with the correct settings in order to talk to each other.I know this radio has enhanced privacy too,would the software read this or would i be better off simply writing new settings to both radios?
I do need to read this radio that has the codeplug password first ( ie I dont want to lose any of its data in first instance)
any help appreciated.
dp3400 programming
- radioenthusiast2011
- radiogaga
- Call Sign: 26TM399
Re: dp3400 programming
Only way, without the password is to recover, this will clear the current codeplug. Or if you are handy with Wireshark you could use a packet sniffer to try and read the password. Not full proof though.
PM me if you want and I'll talk you through it. And the enhanced privacy issue too.
Are you loading DMR MARC codeplug?
BTW - Can't you just ask for the Codeplug pw?
Sam
Sam
30TM399 Northern Costa Blanca
If you need any help let me know since I am local I can assist if needed.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Thanks for replies guys.
Tried Wireshark but it couldnt locate the usb connection to the radio,on the laptop.
The radio i wish to read with the codeplug pw was one of several bought outright from a comms dealer and they in my opinion will be reluctant to release the info.They would most likely want the radio sent to them for programming.
As i say i am new to programming these radios so still in the newbie area.
Even if i could read the radio with the codeplug pw,would i be correct in saying it wont tell me the enhanced privacy key(s) being used??
- wheelbarrow
The wireshark trick won't work on later version CPS (Can't remember when it was exactly) but on older versions you can do it. Otherwise reprogram the radio with a default codeplug from the CPS folder should overwrite it.
If you did read it the security aspects of it (privacy, RAS etc) shouldn't be viewable by you.
- radiogaga
It does with CPS 10.5
- wheelbarrow
Yeah I think it was only fairly recently introduced by Motorola so many radio codeplugs out there will be accessible via wireshark.
managed to get the codeplug pw via wireshark.
may have been my computer,as i had to create a new LAN connection and then scan or start on that one, and then once i read the radio the packets came through no probs at all and managed to source the pw
