Anyone have a CPROG-HX Cable they could lend to me please? Happy to pay a deposit for it's return
Entel CPROG Cable for HX Radios
- radiogaga
- Call Sign: 26TM399
30TM399 Northern Costa Blanca
- radiogaga
Re: Entel CPROG Cable for HX Radios
Anyone? Cheers
- tby
- Call Sign: EI7FO
That cable is one of the most expensive I have come across, you don't need it if you have a CPO40 or an Icom cable, you remove both screws
from the earpiece, remove earpiece cover and either of these cables will then make the proper contact and work, note however that software only recognizes only Com1 or Com2 so if using USB cables go into hardware config-advanced and change to Com2, Win XP, others may differ.
Good Luck.
Good Luck.
- tby
- Call Sign: EI7FO
- radiogaga
I would give that a go but I have a multi pin arrangement on the HX 483 - Similar to that of the GP340
I need one like this:
