The new Baofeng UV-8 cannot programme it!!
Celebritypaul
Call Sign: 2E1HYI
Re: The new Baofeng UV-8 cannot programme it!!
Post by Celebritypaul » 20 Aug 2013, 07:29
Celebritypaul wrote:Yep!!
Another one , except this one can't be programmed from the set :-/
So...
I've Got the correct software , Im using the cable which works all my other kenwood type fitting chinese radios with no issues , but will not read the radio . The usual "Check connections@ message is all.
No info on how to actually programme it in the manual , nobody on Internet talks if them .
So...
I'm stuffed at the moment , with a nice door stopper!
With no offer of compensation other than to return it at my cost to China , the loss will be mine.
The Seller :
"ESHOW.DEALS"
I would advise all to stay clear of this seller.
wasserbueffel
Post by wasserbueffel » 20 Aug 2013, 19:13
OK...
What is (interface with FTDI chipset)?
Special Lead?
Paul
This is also a USB-serial adapter ..
Only other chipsets.
So you do not have the driver problems as with the Prolific chipset.
So I program all my devices!
http://www.amazon.de/Digitus-DA-70156-U ... m_cmu_pg_t
Walter
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 23 Aug 2013, 21:49
OK...
Special Lead?
Paul
Walter
I might try my USB to serial adaptor lead which I have and see what this dose?
Also Ive just taken delivery of a clone lead which Im going to try when I receive my keypad version of this radio through the post . I will programme this by hand and then attempt to clone it with the unprogramnable Baofeng .
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 26 Aug 2013, 17:22
OK...
Special Lead?
Paul
Walter
OK , just to let you all know that (Serial lead didn't work neither) , so that's All the program's and drivers and leads tried .
zlatkobb
Post by zlatkobb » 22 Dec 2016, 19:08
wasserbueffel wrote:Without software, a dual-band device is pointless!
In my UV82 I found no software from the manufacturer.
On the RU servers I have the software found.The is strange!
On the device is at the top and bottom only UV Dual Band 400-520 MHz.
Dual band for UHF frequencies??
dali ste uspeli isprogramirati ovu radio stanicu
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix » 23 Dec 2016, 08:58
On je programiran svoj radio, da. To je pomoću softvera je founf na RU poslužitelju.
Molimo post u engleskom od sada. Hvala ti.(Please post in English, thanks)
