The new Baofeng UV-8 cannot programme it!!
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 14 Aug 2013, 17:32
Yep!!
Another one , except this one can't be programmed from the set :-/
So...
I've Got the correct software , Im using the cable which works all my other kenwood type fitting chinese radios with no issues , but will not read the radio . The usual "Check connections@ message is all.
No info on how to actually programme it in the manual , nobody on Internet talks if them .
So...
I'm stuffed at the moment , with a nice door stopper!
thelad
Re: The new Baofeng UV-8 cannot programme it!!
Post by thelad » 14 Aug 2013, 18:43
Celebritypaul wrote: So...
ah atleast not all is lost.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 14 Aug 2013, 19:16
Ive managed to programe just about every Chinese radio going to date , but this son of a bitch is going back on Ebay.
I would not advise anyone to buy one of these as they simply are not programmable.
though its unbelievably likable in quality. Shame! :(
wasserbueffel
Post by wasserbueffel » 14 Aug 2013, 20:56
Mean Bofeng UV 82??
It can be programmed ...
Software here.
http://www.miklor.com/UV82/UV82-Software.php
I have 2 of the devices, no problems ...
Greeting Walter
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 14 Aug 2013, 21:52
wasserbueffel wrote:Mean Bofeng UV 82??
Software here.
Greeting Walter
Thanks for that Walter....
It is The UV-2 , looks like the same radio to me but without the LCD display.
I will give it a go tomorrow , before I give up after 8 hrs trying to programme it today.
Regards
Paul
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 15 Aug 2013, 08:33
Software here.
Greeting Walter
Regards
Paul
Still dosent work ,in fact its exactly the same software as Ive already tried.
All I get is : "Fail connect radio!!"
So with no help from the supplier ,I would say that after some 10hrs attempting ,these radios Baofeng UV-8 do not seem to be in any way programmable
wasserbueffel
Post by wasserbueffel » 15 Aug 2013, 13:45
Without software, a dual-band device is pointless!
In my UV82 I found no software from the manufacturer.
On the RU servers I have the software found.The is strange!
On the device is at the top and bottom only UV Dual Band 400-520 MHz.
Dual band for UHF frequencies??
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 15 Aug 2013, 19:49
wasserbueffel wrote:Without software, a dual-band device is pointless!
Nothing surprises me much with Chinese radios these days , nothing's guaranteed to be correct as advertised.Ive had radios with scramble in them (Not!!). I had to fit a board to make it work.You don't really know what you're getting or not getting , but you won't be able to send it back , and communication is almost nil.
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 15 Aug 2013, 19:51
Well I tried to get the programmes on my colleagues computer but its windows 7 and the files wouldn't even open on it so that leaves me pretty much stuffed.
wasserbueffel
Post by wasserbueffel » 15 Aug 2013, 20:45
You should also order the relevant known stores.
Since there are no problems with complaints.
At 60 devices that I had bought there only 2 devices problems.
Within 3 weeks, I got new equipment ....
Radio bankers, shop 888, 409 etc.etc shop. I can recommend ..
Ask some at Shop 888
http://www.radioshop888.com/
or 409Shop
http://www.409shop.com/
for the software.
Have already helped me a lot ...
Walter
wasserbueffel
Post by wasserbueffel » 15 Aug 2013, 22:15
Just try this software.
http://www.luiton.com/upload/soft/LT-558UV% 20software.rar
Is this unit
http://www.luiton.com/htm/New-CE-LT-558 ... o_433.html
Maybe it's identical (the battery is the same!)
Walter
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 15 Aug 2013, 23:01
wasserbueffel wrote:Just try this software.
Is this unit
Walter
Looks a bit iffy to me as its not the same radio .
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 16 Aug 2013, 07:44
wasserbueffel wrote:You should also order the relevant known stores.
or 409Shop
for the software.
Walter
409Shop have supplied me with correct software, still won't connect to radio??
wasserbueffel
Post by wasserbueffel » 16 Aug 2013, 10:07
What can you say there?
I had the radios were not to be programmed with Prolific interface.
Had to take an interface with FTDI chipset.
Also allows you to load only in administrator mode, some programs ...
I also had problems with the contact times 2.5 and 3.5 mm jacks ..
Wiggle it a little time ..
Or unit is simply defective.
Celebritypaul
Call Sign: 2E1HYI
Post by Celebritypaul » 17 Aug 2013, 14:02
wasserbueffel wrote:What can you say there?
OK...
What is (interface with FTDI chipset)?
Special Lead?
Paul
