Hi Guys,
Don't suppose anyone would have a copy of an instruction manual for a Kenwood TK361?
I have just been given a couple of hand sets and although the frequency's are the same the CTCSS codes appear to be different.
Any help is appreciated!
Ben
Kenwood TK-361
- BroadsBen
- Call Sign: 26TM109
Kenwood TK-361
26TM109
- Spike
Re: Kenwood TK-361
Cant find a manual off hand but this should help.
Code: Select all
* TK361 SRBR
* 1 - 461.2625MHz - 94.8Hz - Same as Red 1 Motorola
* 2 - 461.4750MHz - 88.5Hz - Same as Green 1 Motorola
* 3 - 461.4875MHz - 103.5Hz - Same as Yellow 1 Motorola
* 4 - 461.4750MHz - 79.7Hz - Kenwood only
* TK361 T2 PMR446
Ch1 Ch2 Ch3 Ch4
446.00625MHz 446.09375MHz 446.03125MHz 446.06875MHz
1 94.8Hz 88.5Hz 103.5Hz 79.7Hz
2 107.2Hz 110.9Hz 114.85Hz 82.5Hz
3 118.8Hz 123Hz 127.3Hz 85.4Hz
4 131.8Hz 136.5Hz 141.3Hz 91.5Hz
5 146.2Hz 151.4Hz 156.7Hz 179.9Hz
6 162.2Hz 167.9Hz 173.8Hz 192.8Hz
7 132DCS 155DCS 134DCS 243DCS
8 311DCS 346DCS 315DCS 351DCS
9 423DCS 664DCS 431DCS 723DCS
* Changing Programmed CTCSS/DCS Tones
* Switch OFF the radio
* Press and hold PTT and LOW (button under PTT) then switch ON the radio
* Select the CHANNEL you wish to program its CTCSS/DCS code
* Press MONI (2nd Button under PTT) repeatedly until you have selected the desired CTCSS/DCS code
* Press LOW (button under PTT) to confirm settings
* Cycle Power OFF then ON to use the new settings
* An increasing number of beeps indicates the chosen tone, 1 long beep = 5 short beeps (9 Max as per above table)
* Changing Programmed Frequencies (i.e. channel position has different SRBR/PMR446 channel attached to it NOT other non SRBR/PMR446 frequencies)
* Select the CHANNEL you wish to program its frequency
* Press PTT repeatedly until you select the desired frequency
Ian
East Northamptonshire Shooting Association
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” Benjamin Franklin
"It is are not raining in Tokyo"
- BroadsBen
Re: Kenwood TK-361
I know i'm bringing up a really old thread here, but I was wondering if anyone was able to help me program these. I'm trying to program the radio to a CTCSS tone but all i seem to be doing at the moment is changing the DCS tone or the frequency. Is any able to give any pointers?
Thanks in advance
Callum
Thanks in advance
Callum
