BAOFENG UV-5R how to enter and save the pmr 446 channels PLEASE
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 01 May 2019, 16:56
Can anyone please help ? i am tring to enter the pmr 446 channels into my baofeng uv-5r radio , i am useing the 6.25 steps but cannot get it to save lets say 446.0062 it saves 446.000 how do i get it to save 446.0062 ??? PLEASE
Ur5by9
Re: BAOFENG UV-5R how to enter and save the pmr 446 channels PLEASE
Post by Ur5by9 » 01 May 2019, 22:19
i'm sure i used a program called chirp and just copied the PMR channels across , took merely 5 minutes, you will need the cable to program the radio from the computer, mines came with the radio .
1 446.003125 MHz 6.25 kHz Allowed for digital FDMA operation after January 2018
2 446.009375 MHz 6.25 kHz
3 446.015625 MHz 6.25 kHz
4 446.021875 MHz 6.25 kHz
5 446.028125 MHz 6.25 kHz
6 446.034375 MHz 6.25 kHz
7 446.040625 MHz 6.25 kHz
8 446.046875 MHz 6.25 kHz
9 446.053125 MHz 6.25 kHz
10 446.059375 MHz 6.25 kHz
11 446.065625 MHz 6.25 kHz
12 446.071875 MHz 6.25 kHz
13 446.078125 MHz 6.25 kHz
14 446.084375 MHz 6.25 kHz
15 446.090625 MHz 6.25 kHz
16 446.096875 MHz 6.25 kHz
17 446.103125 MHz 6.25 kHz
18 446.109375 MHz 6.25 kHz
19 446.115625 MHz 6.25 kHz
20 446.121875 MHz 6.25 kHz
21 446.128125 MHz 6.25 kHz
22 446.134375 MHz 6.25 kHz
23 446.140625 MHz 6.25 kHz
24 446.146875 MHz 6.25 kHz
25 446.153125 MHz 6.25 kHz
26 446.159375 MHz 6.25 kHz
27 446.165625 MHz 6.25 kHz
28 446.171875 MHz 6.25 kHz
29 446.178125 MHz 6.25 kHz
30 446.184375 MHz 6.25 kHz
31 446.190625 MHz 6.25 kHz
32 446.196875 MHz 6.25 kHz
AshtonMobileScanner
Call Sign: 26TM931
Post by AshtonMobileScanner » 02 May 2019, 00:30
There the digital pmr channels on DPMR446
Motorola UHF DP3600 x2,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
CALLSIGN: 26 TM 931 / 26 CT 931
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 02 May 2019, 08:45
Would there be any sence in adding thouse digital channels to my baofeng uv-5r radio ? as i do not think it can handle digital ???
