Baofeng UK Marine channels file
grafter
Post by grafter » 14 Apr 2019, 16:25
I was asked to write a file for a GT-3TP this weekend so thought I may as well share it on here, this will upload using Chirp set to a UV-5R. This is the third GT3 I've programmed for marine band and none of them having the annoying internal birdie on 156.0MHz Channel 0 that is a problem with some of the other models.
Channel 0 is programmed with a large split but given that it's a two second job to manually enter and transmit anywhere on VHF there doesn't seem much point censoring the original file.
UKMARINE.zip
MickeyFKNMouse
Call Sign: 26TM713
Re: Baofeng UK Marine channels file
Post by MickeyFKNMouse » 18 Apr 2019, 12:30
I have a gt3tp and I have the birdie on 156.0 I always have to exclude this from scanning and manually select it.
11m 26TM713
446 DMR TM713
RadioShack TRC-1014
AOR Ar8000mk2
Ailunce HD
Tait T2010
QYT KT7900D
Baofeng GT3 TP
Alan 42
Puxing PX888k
AOR AR82000
Baofeng BF888s
Not a ham but use CB and 446
Mobile and HT around South West Cornwall and sometimes Lincolnshire around Waltham
Licenced Business user
LeakyFeeder
Post by LeakyFeeder » 22 Apr 2019, 20:14
16 and ch0 are the two main channels to listen to.. there are also 7channels ALB to Y boat that are worth listening to
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 28 Apr 2019, 10:01
Hi LeakyFeeder, please can yoy explain more about these ALB to Y channels ,I live on the wash in norfolk so they could be usefull to me ,
