Motorola Codeplug wanted
radiogaga
Call Sign: 26TM399
Post by radiogaga » 21 Sep 2016, 19:54
Hi all
Does anyone have a Motorola DP4400 UHF codeplug then could send me please?
Doesn't matter what is in it, can be blank, just need it to recover my 4400 which I've forgotten the codeplug password for and can't find the previous read.
Samples in the CPS are for a VHF radio not UHF unfortunately.
30TM399 Northern Costa Blanca
moj
Re: Motorola Codeplug wanted
Post by moj » 21 Sep 2016, 23:17
which cps do you need it working on , i've got 12.1 codeplug here m8 if that's any use ?
radiogaga
Call Sign: 26TM399
Post by radiogaga » 21 Sep 2016, 23:42
Thanks.. should be fine, using 12.5...
Can you upload to a dropbox or similar please?
Ta
moj
Post by moj » 22 Sep 2016, 10:29
radiogaga
Call Sign: 26TM399
Post by radiogaga » 22 Sep 2016, 10:54
Top Man :P
moj
Post by moj » 22 Sep 2016, 14:35
no problem , let me know if it works ..
radiogaga
Call Sign: 26TM399
Post by radiogaga » 22 Sep 2016, 14:40
It does :) Thanks
radiosification
Post by radiosification » 08 Oct 2016, 00:39
I know I'm a bit late, but for future reference or for anyone else reading this thread you can usually find a folder with default codeplugs for most radios already on your computer. It gets put there when you install the MotoTRBO CPS.
radiogaga
Call Sign: 26TM399
Post by radiogaga » 08 Oct 2016, 05:09
It does but the DP4400 is for the VHF radio not UHF.
radiosification
Post by radiosification » 09 Oct 2016, 14:33
radiogaga wrote:It does but the DP4400 is for the VHF radio not UHF.
Ah sorry, my mistake, I just saw that you did mention the samples in your first post. However it was only a brief mention so hopefully my post will help someone in the future searching the forum for a sample codeplug
macuser
Post by macuser » 02 Apr 2017, 17:20
Hallo und good evening, i need a codeplu for my DP4400 UHF. I have the same problem with the password and the same VHF codeplug in the cps.
Can anybody help me?
(sorry for my very bad english...)
Squirrely
Post by Squirrely » 01 Mar 2019, 04:28
moj wrote:
22 Sep 2016, 10:29
https://www.dropbox.com/sh/j4snmlm1zkuj ... Mu4Wa?dl=0
there you go mate ;)
Hey, any chance you could re-upload that codeplug? i also require a copy, thanks!
