US Radios into the UK
2wayfreq
Call Sign: Ki6WKV
Post by 2wayfreq »
Hello,
I'm curious, I may retire to Scotland in the not to distant future. Are there any restrictions of US Model radios (Motorola, Kenwood, Harris etc. being brought over there? Do they have to meet a certain criteria?
Motorola XPR6500 TRBO UHF
Motorola HT750 UHF
Motorola XTS5000 VHF
GE M-RK UHF
TIDRadio TD-M8 UHF
scottyboy
Re: US Radios into the UK
Post by scottyboy »
Only issues I can think of would be the channel spacing, if 25khz then that would be an issue if going to transmit
And frequency range in the US radios tends to be different from the EU versions so your radios may not work on specific allocations.
Apart from that I don’t think there would be a problem.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
2wayfreq
Call Sign: Ki6WKV
Post by 2wayfreq »
Ok,
Well that's encouraging news. Thank you Scottyboy!
Cheers!
Motorola HT750 UHF
GE M-RK UHF
TIDRadio TD-M8 UHF
26mb04
Call Sign: 26DG01
Post by 26mb04 »
It might be worth stocking up on spares for them before you get here, some of the older commercial gear (Motorola Saber, Harris etc) are almost unheard of in the UK. Getting parts will mean either China-made gear, or importing from USA. Mega money!
Sent from my GP300 using DTMF
