FRS vs. GMRS - coverage area
rooth
Post by rooth » 28 Nov 2017, 19:09
What is the difference as the coverage area if I emit 0.5W in FRS versus 0.5w in GMRS.
Does anyone know to explain?
Re: FRS vs. GMRS - coverage area
Post by Admiral » 28 Nov 2017, 19:43
None at all as half the channels are shared between FRS and GMRS and the rest are a gnats willy away.
radiosification
Post by radiosification » 29 Nov 2017, 00:19
Your location is showing on your profile as Romania. FRS and GMRS are for use in the USA and it is probably illegal to use them in Romania. In Europe we have our own version which is legal here, called PMR446.
Apologies if you knew this already but since you're quite a new user and are asking about this stuff when you're in Romania, I thought I better tell you just to be sure.
rooth
Post by rooth » 29 Nov 2017, 16:03
@radiosification:
My question was generic. I see 0.5W FRS / GMRS devices that say they emit 10-15 miles and look the same as the 0,5W PMR of Europe.
I was wondering where the big difference in coverage is ?
Auldgeek
Post by Auldgeek » 29 Nov 2017, 19:29
rooth wrote:
29 Nov 2017, 16:03
@radiosification:
Optimistic advertising! :lol:
Range will depend greatly on, and is a combination of power, receiver, antenna and terrain. Terrain is especially important at UHF.
As these allocations are essentially the same, assuming you had PMR446/FRS/GMRS equipment side by side, with same power, antenna and receivers were of similar spec, you should expect to achieve a similar range.
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
rooth
Post by rooth » 30 Nov 2017, 07:35
And then where is the difference of coverage up to 35 miles even to those FRS or GMRS 0.5W power assuming we are in the free field. However, the PMR do not pass 8-10 km maximum under ideal conditions.
Is it somewhat higher frequency?
M3HIM
Call Sign: M3HIM
Post by M3HIM » 30 Nov 2017, 15:15
FRS and GMRS share frequencies in the 462MHz and 467MHz bands with unlicensed users limited to 0.5W. PMR446, as the name implies, uses frequencies in the 446MHz band with a limit of 0.5W. As all three services operate on similar frequencies and power levels, the coverage area is similar and typically 5-10km in open space but much less in an urban environment.
However, licensed users of FRS / GMRS can operate on higher power (2W, 5W, 50W) depending on the channel range in use and GMRS also supports duplex repeaters.
PMR446 (analogue) and FRS use 2.5kHz FM deviation whereas GMRS uses 5kHz FM deviation which can improve signal range.
Some unscrupulous advertisers may quote coverage area based on use of repeaters, external antennas or higher power which is not available to unlicensed users.
So, generally speaking, 0.5W simplex with an integral antenna on UHF will get you 5-10km with terrain and conditions allowing greater coverage in some circumstances but much less in others.
Félim M3HIM
26-CT-909 / 26-TM-989 / 26-FRS-001 / 26-IRC-909 Aylesbury, Buckinghamshire, England/UK [IO91ot]
29-CT-909 / 29-TM-989 / 29-FRS-001 / 29-IRC-909 Sandymount, Dublin, Ireland/Éire [IO63vi]
Auldgeek
Post by Auldgeek » 30 Nov 2017, 18:00
rooth wrote:
30 Nov 2017, 07:35
They operate on the same general part of the UHF spectrum. It's the advertising that's incorrect.
Are you reading this information from somewhere or actually have evidence that this is the case? I ask because there is no "practical" difference between these bands. Is this line of sight (point to point) or through a repeater? Anyone can get 40 miles through a repeater.
As I previously posted, if you had identical equipment on these bands, you would expect the same coverage. You cannot simply magic an additional 25 miles from nowhere.
M3HIM
Call Sign: M3HIM
Post by M3HIM » 30 Nov 2017, 20:32
From Wikipedia: "The best known [PMR446] long distance record is 333 mi (535.8 km) from Blyth in the United Kingdom to Almere, Netherlands. This was the result of enhanced propagation conditions, not a line-of-sight signal."
https://en.m.wikipedia.org/wiki/PMR446?wprov=sfla1
Félim M3HIM
