Base antenna for 446 mhz help needed
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 27 Oct 2017, 18:25
just bought and received a base antenna for PMR446 Mhz, e/bay item number 302491369589 from stanislavpalo130 when i tested the antenna i find there is a short between the inner section and outer section of the coax cable should this be so ???
Re: Base antenna for 446 mhz help needed
Post by paulears » 27 Oct 2017, 19:11
I bought one from him too, and it's sitting here and I can confirm it's a DC grounded antenna, so the short is correct. Mine actually works rather well on 433 and 453 too! Mine is 1.17 VSWR at 448.1MHz at it's best on the analyser.
gmham
Post by gmham » 28 Oct 2017, 12:46
So if it's showing it's lowest vswr on 448.1mhz can I ask what it's showing on it's intended design freq off 446mhz ?
.... Icom IC7300 / Cobra 148gtldx Mk2 / Kenwood TR751e 2mtr ssb... Ameritron ALS-600X SS HF Linear.... Cushcraft R6000 HF vertical / 80-10 mtr ocf dipole....... Astatic 575m6 mic / Heil ICM mic.
108-TM-154 - John
Post by paulears » 28 Oct 2017, 14:17
1.2 I spotted these about a year ago and have had a UHF high band one and the 446, and the tuning is quite sharp, it's not got much response at any other frequency, then suddenly takes a dive right down. It's handy for 449MHz too. I tried to make something very similar, and found that inside mm accuracy was critical at UHF, and while with wideband designs it doesn't matter.
EDIT - I've just spotted that I mixed them up. The ones I have are these ones 302501691331 (in 446 and 453 versions)
Which is a half wave design, compared to the 5/8th one this post relates to - mine of course is not tenable, being sealed in the tube, while the ⅝ version is.
He makes decent quality kit, and while I make a few myself, his are neater and surprisingly light!
Post by Admiral » 29 Oct 2017, 13:40
"DC ground coil for full static protection"
He put a clue in the listing, you will still need to make sure you ground it though. Plus, it has an N connector, so make sure you get one of those on the end of your coax as adaptors outdoors will invite moisture and could be lossy if they are ten bob Chinese things.
Steve B
Post by Steve B » 29 Oct 2017, 16:18
WARLOCK wrote:just bought and received a base antenna for PMR446 Mhz, e/bay item number 302491369589 from stanislavpalo130 when i tested the antenna i find there is a short between the inner section and outer section of the coax cable should this be so ???
I love that guy's antennas. They are good ****. They work on principles of gamma match magic. Bought a yagi from him a while ago and have made 100+ mile contacts with it.
30-Tango-Mike-003
Good Christian Boys: Midland G7 XTR "Street-Legal" PMR 3-watter - Kenwood UBZ-LJ8 PMR446 - Intek FM548SX (With Homogolation boys 8) )
