Kirisun S780
Kirisun S780
Could anyone help please? I need the programming software on a disk (one is not supplied with the radio). I have no internet at home, it will not download in the public library. If anyone has a disk that they could supply (for Windows 8 or XP SP3) I would be very grateful, thanks.
Re: Kirisun S780
One last roll of the dice beforehand, can you connect to TM1 with a phone?
If so, try downloading the attached to your phone, use an OTG cable to send to a USB stick, or use a double ended OTG compatible USB stick, they're less than a tenner if you don't have one, then transfer to the PC. Sounds a kerfuffle but should only take 5 minutes.
