white stick
radiospy
white stick
Post by radiospy » 06 Dec 2015, 23:55
hi im new to this i have a uv5-r and whant to use a 70 cem white stick how fare will the swr be out on 446mhz as i do not a swr meter :( :(
Mitch
Re: white stick
Post by Mitch » 07 Dec 2015, 16:54
You could invest in a cheap meter (fleabay), or just set any adjustments to their lowest. These aerials are usually made to cover 430-450Mhz for the Americans, 446 being at the top end, shorter wavelength etc. it shouldn't be far off.
The perfect face for radio.
GeeFull
Re: white stick
Post by GeeFull » 08 Dec 2015, 14:14
radiospy wrote:hi im new to this i have a uv5-r and whant to use a 70 cem white stick how fare will the swr be out on 446mhz as i do not a swr meter :( :(
It won't be any further "out" than the as supplied less than marvelous dual wideband rubber duck, that is generaly tuned anyway for the radios VHF/UHF capabilities.
I doubt the radio will see it as any worse a "load" than the supplied stock one.
Registration
Banned
Banned
Re: white stick
Post by Registration » 10 Dec 2015, 17:09
If your device is from Baofeng I would use it only to receive Calls.
kr0ne
Re: white stick
Post by kr0ne » 11 Dec 2015, 00:57
Why?
Registration
Banned
Banned
Re: white stick
Post by Registration » 11 Dec 2015, 01:21
its illegal sending anything out with an baofeng on pmr446
1) removable antenna
2) mir that 0,5W
GeeFull
Re: white stick
Post by GeeFull » 11 Dec 2015, 10:34
Registration wrote:its illegal sending anything out with an baofeng on pmr446
2) mir that 0,5W
I am sure he will take good note of that commonly known, but rarely adhered to fact! ;)
kr0ne
Re: white stick
Post by kr0ne » 11 Dec 2015, 20:55
Maybe the OP is licensed for 5W on 446MHz... :geek:
:lol:
