This new radio seems to be locked in 2CH (Dual Watch) mode.
Prob my fault, but I can't get it out of this mode! As a result I can't set the channel/sub channel I want.
Had PMRs for many years, but stumped with this prob.
I've read the manual but no joy.
Also tried to do a factory re-set like thus:
Press MON button + note button (♪) both at the same time + Power Menu button on the right just second after, without letting go the other 2 buttons. When you do this it should turn on and it will display a screen sequence of all available items. Then press Power off, then power on.
But it doesn't work!
Any ideas guys?????
bumperman
Motorola TLKR T60 problem.
- New User
- New User
Re: Motorola TLKR T60 problem.
Problem now sorted.
Looked in manual for earlier TLKR T6 model & found solution there!!!!!!!!!!!
bumperman
bumperman
