CB mike on PMR446?
CB mike on PMR446?
Maybe this is a daft question, but is it possible to wire a CB power microphone to use with a PMR446 set or two-pin input Amateur radio handheld radio? Thanks.
- Call Sign: RDX64
Re: CB mike on PMR446?
Simple answer - Yes.
How well it works, if the mic impedance's are going to match etc is another matter.
We would need to know more about the radio & the mic to advise on that - model numbers etc.
You do know that you can buy mics that plug into these radios quite cheaply anyway don't you?
As above, yes, you can wire virtually any mic to virtually any set, but what it sounds like is another story.
Power mics are not generally suited to FM, they often cause over deviation before any sound improvement is achieved.
Off the shelf 446 sets generally use an electret mic element and will mean the circuitry is set up for an electret, use anything else and chances are it won't work well, if at all.
- StormShadow
I've done it lots of times not specifically for PMR446 but for PMR stuff in general, I like to re-purpose old PMR gear for Amateur use and such things like that... I've used CB mics a lot when I get a radio that has no mic to it. I occasionally like to build my own mic's as well.
