49mhz Walkie Talkie Frequncy
Hi guys, I just got some 49mhz Walkie talkies off eBay for a tenner. Does anyone know what frequencies they'll work on? I'm assuming they're multi channel as they have a few buttons on.
CHECK OUT MY RADIO BLOG
http://distantsignalradio.blogspot.co.uk/
My Youtube
https://www.youtube.com/channel/UC67TJP ... i2h1aaSO6Q
My Youtube
Re: 49mhz Walkie Talkie Frequncy
Would suggest a local frequency counter and play with the buttons!DistantSignal wrote:Hi guys, I just got some 49mhz Walkie talkies off eBay for a tenner. Does anyone know what frequencies they'll work on? I'm assuming they're multi channel as they have a few buttons on.
A common one many years ago for the single channel variety, was 49.860, but they varied quite a bit from manufacturer set to set!
Some early ones were AM, a lot of the later ones FM!
Do you have a scanner or reciever at hand that covers 49 Mhz?
Would help ascertain what mode they are on also!
Well, as a rough guess I'd say they were FM with 5 channels between 49.830 and 49.890.
CH1=49.830
CH2=49.845
CH3=49.860
CH4=49.875
CH5=49.890
http://uk1ab.no-ip.biz/TRC-503-49mhz_fi ... 503_sm.pdf
CH1=49.830
CH2=49.845
CH3=49.860
CH4=49.875
CH5=49.890
Cheers guys!
My Youtube
My Youtube
- Call Sign: uk018
Hi there
I have been using 49 MHz for a while now.
Don't expect to much in the way of DX out of these radios, my sets are around 10 MW output.
Range tests have resulted in a distance of around 30 to 50 M.
Using the sets with a ¼ wave antenna has increased my range, I have walked up my road and not lost the signal.
I know this test isn't very scientific, its just my test.
http://uk1ab.no-ip.biz/49mhz.html
The radios I used for the range test were, MAXON PC-50 as the base with added antenna and the mobile was a Realistic TRC-503.
These are 5 channel FM sets
I have the MAXON connected to FRN free radio network as a gateway, works well around the house.
73 de Wes
73 de Wes
- Call Sign: uk018
- curny
Nice to see someone else experimenting with 49mhz!
I did have a beacon set up with one of those Maxon vox operated sets and a MP3 player just to test various antenna configurations and ranges
Curny
163-TM-336
163-CT-336
'UK Three Thirty Six' on midband AM
163-TM-336
163-CT-336
- LeakyFeeder
Is 49mhz like 50mhz aka 6m?
Fire up the 706.......
- Call Sign: uk018
Hello
after my last posting on 25 Oct 2015 I set up a beacon on my 49 MHz FRN gateway, this goes out every 15 minutes 24/7.
If anyone should hear it please send me an e-mail to the address that is announced on the beacon.
The frequency of this beacon is ( 49.860 MHz FM )
Please have a listen out on this frequency with your ICOM or YAESU radios and send me an e-mail.
The e-mail is announced on the beacon.
ps I chose this channel because it is free from baby monitors around here, you might not be so lucky.
Good luck
73 de Wes.
Good luck
73 de Wes.
49mhz walkies are crap and get mega noise and interference from baby monitors be lucky if you get up the road
- FakeJake
- Call Sign: 2E0SEY
Sounds like they double up as a nice hand warmer in the winter months! How big is the battery for it?UK018 wrote: my sets are around 10 MW output.
Jake 2E0SEY
Saltney, near Chester (Cheshire-Flintshire border)
Monitoring 2m simplex (when I can)
Dysgwr Cymraeg
Dysgwr Cymraeg
Well they'll need a lot of power to get out, according to half the posts on this thread they're down at 49 millihertz. Winds me up no end as I actually use millihertz at work (frequency drift) so the old noggin doesn't auto-correct to Megahertz without stopping and thinking about it first.FakeJake wrote:Sounds like they double up as a nice hand warmer in the winter months! How big is the battery for it?UK018 wrote: my sets are around 10 MW output.
- FakeJake
- Call Sign: 2E0SEY
If my calculations are correct, that's a wavelength of over 6 million km!
Jake 2E0SEY
Dysgwr Cymraeg
Dysgwr Cymraeg
Indeed. No wonder they need 10 Megwatts into those tiny little antennas.FakeJake wrote:If my calculations are correct, that's a wavelength of over 6 million km!
That's odd, I didn't see a single reference to mHz, just all upper or lower case MHZ and mhz.BK wrote:
