http://www.n5dux.com/ham/files/pdf/ATV% ... 20Oven.pdf
It looks like NBFM is also possible! How's up for some 2.4GHz DX:ing?
This text file in turn references that first one and mentions that someone getting 650W pep out from one.
http://www.qsl.net/kd6pag/usenet/MicrowaveOvenXmtr.txt
And here's some more talk:
http://www.dxmaps.com/discuss/oven.html
That one is interesting due to the OH2AUE mention that if one magnetron is phase locked and a second one is driven to the same waveguide, the second magnetron will injection lock to the first one, giving double the power quite easily.
There are also some scientific papers out there on the subject. The most interesting one dealt with using magnetic bias for phase locking the magnetron. Using an electromagnet to do it would be advantageous because that would save one from building the 4.5kV regulator for the magnetron supply voltage.
The first pdf file has some pictures.Admiral wrote:As kr0ne said to cowpat, 'pictures or it didn't happen'DX-Digger wrote: I have a design somewhere on how to convert a microwave oven into an atv transmitter producing 250W
Earth-Venus-Earth bounce with a large dish and phase locked 2.4Ghz magnetron:
http://www.qsl.net/dl4yhf/speclab/earth_venus_earth.htm
In addition to magnetrons, scrap dealers and ebay have tons of used 3g amplifers for the 2140MHz band, and those have the potential to produce some serious power on the 2.3GHz/2.4GHz bands. A "50W WCDMA" amplifier will gladly do +200W SSB after being tuned up.
