LPD Channels
- mayhemicmayhem
LPD Channels
Can I presume that it is okay to use the LPD channels on high power if you've passed your Amateur license?
- Gaygordon
- Call Sign: M0xxx
Re: LPD Channels
If you've got a licence forget all about LPD. It's 70cms as far as you're concerned and the whole band is yours to play with.
Re: LPD Channels
Exactly what Gordon said, of course ensuring you stick within whatever licence class power restrictions apply, and respect the long established "band plans"!Gaygordon wrote:If you've got a licence forget all about LPD. It's 70cms as far as you're concerned and the whole band is yours to play with.
The allocation of LPD set spot frequencies and associated power restrictions, should not even be considered as applying to someone with an amateur licence!
Why piddle about with LPD, when you already have far more on offer, delivered on a plate?
- DX-Digger
- Call Sign: TM205
Re: LPD Channels
Your amateur radio licence allows you to contact other licenced amateur radio users, you are not licenced to contact LDP users, as they do not have the necessary licence!
Because of your higher power status you could also be accused of deliberately interfering with them.
I for one would steer clear of such frequencies and their operators!
Re: LPD Channels
You are quite correct, conversing cross "licencing", ie licenced amateur to LPD user, is not sanctioned by Ofcom!DX-Digger wrote:Your amateur radio licence allows you to contact other licenced amateur radio users, you are not licenced to contact LDP users, as they do not have the necessary licence!
But sometimes avoidance could prove difficult when many such LPD channels coincide with some 70 cms Simplex!
I would say the oposite logic applies, any LPD users avoid fequencies where you "hear" licenced amateurs in QSO, after all, you may well be hearing them, but there is absolutely NO garantee, on your, "Ahem!", restricted power level, they will be hearing you!
Just a thought!
- DX-Digger
- Call Sign: TM205
Re: LPD Channels
Most Ham operators who frequent 70cms usually do so with a very sensitive radio set up.GeeFull wrote:You are quite correct, conversing cross "licencing", ie licenced amateur to LPD user, is not sanctioned by Ofcom!DX-Digger wrote:Your amateur radio licence allows you to contact other licenced amateur radio users, you are not licenced to contact LDP users, as they do not have the necessary licence!
Just a thought!
But of course it is possible to not hear LPD users.
However, lets say you heard a weak signal on your frequency, you know someone is there, but you cant identify them so you think oh well ill crank the power up so they know this frequency is in use!
Who is to say that they are not the primary band users (military?) as no call-sign will be used to identify them,
start interfering with them and you would quickly find your licence revoked!
I know that is a rather extreme example but we have to be extra careful on bands where we are secondary users!
If I hear a station on 70cms and I hear nothing to indicate it is a licenced ham station I would just leave them be.
Well actually,to be honest, I think I would have a listen to see what was going on, but of course I would never publish what I hear
Re: LPD Channels
Aren't some LPD channels smack on the repeater freqs? If I was an LPD user I think I'd stay off those - either I'll spoil someone else's fun or they'll blast across me.
Re: LPD Channels
To be honest I've never really used LPD433, maybe if i want an interference free channel but for me CTCSS/DCS always solves my problems with that (or failing that channel 9) .
pmr446 king.
Re: LPD Channels
even if it's on a repeater frequency, you won't activate the repeater unless you happen to be using the same CTCSS too. even then, you won't be able to hear the licensed amateurs blasting you unless you're in close proximity to themscanhermit wrote:Aren't some LPD channels smack on the repeater freqs? If I was an LPD user I think I'd stay off those - either I'll spoil someone else's fun or they'll blast across me.
Midland G7 XTR
Baofeng UV-5R+
Motorola XTNiD
Uniden Bearcat 3500XLT
Baofeng UV-5R+
Motorola XTNiD
Re: LPD Channels
Code: Select all
- ChickenMadras
Re: LPD Channels
I'm amazed anybody bothers with LPD for voice comms.
LPD is aimed at short range data communication (burgler alarms, wireless doorbels etc). For voice, you could get more range by shouting.
LPD walki-talkies are a waste of money.
The devil finds work for idle circuits
Re: LPD Channels
I dunno - see this post: http://www.transmission1.co.uk/viewtopi ... 24#p358822ChickenMadras wrote:I'm amazed anybody bothers with LPD for voice comms.
Re: LPD Channels
The LPD channels share the input frequencies for repeater channels RB01 to RB07 and the output frequencies for repeater channels RB03 to RB15. This means that for repeaters on channels RB03 to RB07, you can work the repeater using an LPD radio by switching manually between the input and output frequencies, which is quite practical if you have them programmed into adjacent memory channels. I've actually done this (don't worry, I'm a licensed ham) and managed a range of a mile or two line of sight. Repeaters are generally high up, have moderately high gain antennas, and have higher output power and a more sensitive receiver than handheld radios do. They're designed to maximise the range of a low powered handheld radio, that's their intended purpose, and many of them are quite good at it.
Edit: I've just checked using the ruler tool in google earth, and the range was actually just over half a mile. So not quite as impressive as I thought, but still an interesting experiment.
- ChickenMadras
Re: LPD Channels
I still disagreescanhermit wrote:I dunno - see this post: http://www.transmission1.co.uk/viewtopi ... 24#p358822ChickenMadras wrote:I'm amazed anybody bothers with LPD for voice comms.
Yes, sometimes you can get more range than expected from voice LPD (as your link shows), but this obviously is not reliable. Anybody buying LPD walki-talkies to use seriously will be very disapointed with their performance.
Of course, us radio geeks might like to fiddle with them and see what they can do, but none of us would ever use them as a serious means of communication, nor would we recommend any body else does so. I still reckon LPD walki-talkies are a waste of money
