446 Parrot repeater online!!
- Excalibur
Re: 446 Parrot repeater online!!
I would recommend using PMR446 instead of LPD433 as I stated earlier other users use LPD433 but on PMR446 its LICENCE FREE and has no licensed users on it so there is almost no chance of you causing interference to genuine licenced users! Just stay away from LPD433 it's just asking for trouble
- Gaygordon
- Call Sign: M0xxx
Hell yes, why not? Then you'll only be causing a nuisance to PMR446 users who just want to go about their (legal) business. I'm sure they won't mindExcalibur wrote:I would recommend using PMR446 instead of LPD433 as I stated earlier other users use LPD433 but on PMR446 its LICENCE FREE and has no licensed users on it so there is almost no chance of you causing interference to genuine licenced users! Just stay away from LPD433 it's just asking for trouble
Unless the repeater is broadcasting 24/7, I don't see how it will cause a nuisance and hog the channel. Legal users who don't use the same channel/CTCSS won't trigger the repeater and so won't notice anythingGaygordon wrote:Hell yes, why not? Then you'll only be causing a nuisance to PMR446 users who just want to go about their (legal) business. I'm sure they won't mindExcalibur wrote:I would recommend using PMR446 instead of LPD433 as I stated earlier other users use LPD433 but on PMR446 its LICENCE FREE and has no licensed users on it so there is almost no chance of you causing interference to genuine licenced users! Just stay away from LPD433 it's just asking for trouble
Midland G7 XTR
Baofeng UV-5R+
Motorola XTNiD
Uniden Bearcat 3500XLT
Baofeng UV-5R+
Motorola XTNiD
- kr0ne
I'm afraid that this information is completely incorrect:Excalibur wrote:as I stated earlier other users use LPD433 but on PMR446 its LICENCE FREE and has no licensed users on it so there is almost no chance of you causing interference to genuine licenced users!
http://spectruminfo.ofcom.org.uk/spectr ... mit+search
might not be a good idea to use lpd i would of thought they would moan as well
we aint all moaners i like the fact your doing a simplex repeater its the old fart g's you have to worry about!!
- MrWeetabix
- Admin
- Call Sign: 26TM175
with respect, though you are technically "in the right", there's no sense in prodding a sleeping bear is there?
It's legal, maybe, but why draw attention to yourself?
- Banned
If someone can hear your repeater more than a few hundred yards away on 433 you're not legal and you can expect an amateur hearing it to drop a line to OFCOM who can then DF you using their nationwide network of receivers from the comfort of an office chair at Baldock.LPD devices must only be used with the integral and non-removable antenna with a maximum legal power output of 10 mW.
- kr0ne
I'm pretty sure that even at 10mW a repeater is technically illegal...
Once again, I'm not saying don't do it - just be sensible about it. Setting an illegal repeater up on a freq that amateurs monitor is just asking for the wrong people to notice you.
