PSR-295 and PMR446 incompatibility
kr0ne
Re: PSR-295 and PMR446 incompatibility
Post by kr0ne » 10 Mar 2014, 22:48
Bogget wrote:All 446 frequencies are 12.5k (not 6.25 as many say) it all depends on your radio and where you start, so if you start on the correct freq and every 12.5 going up you will be right.
How do you get onto the correct frequency to start with if you don't have 6.25kHz steps?
Bogget
Post by Bogget » 12 Mar 2014, 20:08
I type it in?
what you say is only relevant on channelised radios where they stick to set channels displayed as freq not the case on most modern radios. So once you set a starting point and this can be any frequency if your radio has only 12.5 steps it is fine and every 12.5 going up fits perfectly.
So for example on my 897 i can set any freq from 100htz divisions eg. 446.00011 (made up freq) set it to 12.5 step the next freq at one click up would be displayed as 446.00136 etc etc.
Bogget
Amateur does not have a CH its pronounced "am-a-tore" NOT am-a-chure !
scanhermit
Post by scanhermit » 12 Mar 2014, 20:16
I tried directly typing in the PMR channels since the dedicated PMR bank doesn't work but it just goes to the nearest 12.5khz step. But as noted above, the Grecom is a bit of a dead loss for PMR.
Bogget
Post by Bogget » 12 Mar 2014, 20:18
Yes so your radio is channalised but displayed as freq (bit of a con really).
Bogget
scanhermit
Post by scanhermit » 12 Mar 2014, 20:32
Bogget wrote:Yes so your radio is channalised but displayed as freq (bit of a con really).
Bogget
The PMR mode displays both channel number and frequency, and the frequency starts on the correct offset. But, as we have established, it's pants. The standard tuning mode for the 400mhz range is in 12.5khz steps. Given that the set is old and (according to the chap who gave it to me) cost £140, it's probably one of the cost compromises made in its design. And perhaps narrow band was not so common when it came on the market.
Bogget
Post by Bogget » 13 Mar 2014, 19:22
Yes this was the case on older radios,......shame.
Bogget
pete_uk
Post by pete_uk » 15 Mar 2014, 14:36
scanhermit wrote:Just been slavering at the Uniden that does digital and trunk tracking (BCD396XT). The reviews say that it's good but a pig to program and get used to. Plus it's quite dear :(
Wouldn't be of any use if you are in the UK.
The 3500xlt and a copy of BCTool (plus cable) will serve you well. Very well.
scanhermit
Post by scanhermit » 16 Jul 2016, 22:13
Postscript to this subject: I dug the PSR295 out of the cupboard to use as my homebase (my Uniden 125 xlt is my out and about scanner) and went to the preset PMR446 band and realised that Grecom have programmed in 466.whatever - 20mhz away from the feckin' band!
Oh well.
