Hyt TC2110- Software Wanted
tby
Call Sign: EI7FO
Post by tby » 29 May 2013, 08:31
Hi all,
Been given a couple of these to programme by a Local sports Club, they want them to work with some other radios that they have, can do the tones manually as per some basic Instructions that I found, but problem is that I cant find a way to change the frequency to line up with their other makes, the 446 frequency on Ch 1 is actually 446.08125(7) instead of 446.00625(1), can you use software to set up frequencies back to factory original, so that all the different makes of radios will all be on same specific channel number.
Been trying to sort for a while, like to get them out of the way,
Thanks,
wasserbueffel
Re: Hyt TC2110- Software Wanted
Post by wasserbueffel » 29 May 2013, 10:35
tby
Call Sign: EI7FO
Post by tby » 29 May 2013, 20:41
Thanks for the link, never thought of looking there!
tby.
rooth
Re: Hyt TC2110-ROGER KP 22 Software Wanted
Post by rooth » 13 Aug 2017, 12:15
The interface made by me, works ok.
Radio does not require programming mode, read directly after port 1 has been tested.
The software has been modified by me for easy installation with MAX 232.
Everything works flawlessly!
Software identical to -ROGER KP 22 .
Link programing software Hytera HYT TC2110 / ROGER KP22 :http://zoomgps.ru/support/25/
( KP-22 Programming Suite )
