446 simplex repeater up and running west London
- Call Sign: FRANCISUK22
Re: 446 simplex repeater up and running west London
Ok, I have tryed to get into the repeater from Stoneyfields Park without no luck, Will try again in Edgwarebury Park tomorrow. However 2AM this morning i could hear the repeater IDing and i cant has the repeater been moved or is the power down?
Now: TYT UVF1, Baofeng UV-5R, Baofeng BF-888s
Previously: Binatone Terrain 550, Alan HP450
Scanners: ICOM IC-R5 with MRW-210 Super Gainer Antenna - Grecom PSR-282
- radiosification
You mean with no luck Francisfrancisuk22 wrote:Ok, I have tryed to get into the repeater from Stoneyfields Park without no luck, Will try again in Edgwarebury Park tomorrow. However 2AM this morning i could hear the repeater IDing and i cant has the repeater been moved or is the power down?
No the repeater is working fine and is still running at 4watts into the high gain antenna. For one more day
Well there has been quite abit of activity on the "buggie" as it was called today!
Somone in edgeware Has worked into it but don't know what they where using ?
You might of caught it on good conditions at 2am but the thing with UHF if your listening to signal and you move 4inches you could lose it. So critical at the part of the band.
yeah you lucky so and so! I was cover in this http://a8.sphotos.ak.fbcdn.net/hphotos- ... 1462_n.jpg but hopefully Edgwarebury Park will bring me luck http://www.panoramio.com/photo/17766455radiosification wrote:You mean with no luck Francisfrancisuk22 wrote:Ok, I have tryed to get into the repeater from Stoneyfields Park without no luck, Will try again in Edgwarebury Park tomorrow. However 2AM this morning i could hear the repeater IDing and i cant has the repeater been moved or is the power down?
Was the call sign K003-R, Its not me but it was clear as anything. I know radiosification was getting into it today Audio from scanner http://soundcloud.com/francisuk22/pmr44 ... est-1-westRG8mini wrote:Somone in edgeware Has worked into it but don't know what they where using ?
if someone said and keep repeating about Edgware then it was me, I key up saying "this is a simplex repeater tested from edgware can you hear me"RG8mini wrote:You might of caught it on good conditions at 2am but the thing with UHF if your listening to signal and you move 4inches you could lose it. So critical at the part of the band.
Was you testing different channels with someone? If so i could hear that person but i couldn't hear you Jay. That was in stoneyfields park aswell (for the record)
- radiosification
I think its UK003-Rfrancisuk22 wrote: Was the call sign K003-R, Its not me but it was clear as anything.
Yep from http://www.transmission1.co.uk/forum/vi ... =4&t=30906radiosification wrote:I think its UK003-Rfrancisuk22 wrote: Was the call sign K003-R, Its not me but it was clear as anything.
Me to the gateway
http://i.imgur.com/OJwd5.jpg
- g0oiw
Tee, hee, PMSL, LOL, chuckle chuckle etc!
The lovely irony of the choice of 82.5Hz CTCSS for a pirate repeater has been noted!
More seriously: I have a couple of good high spots in East Berkshire where I should just about be able to hear this. Accessing it might be more of a problem, though.
- Bogget
Please dont tell me you mean the man from U.N.C.L.E. or did you miss that linkg0oiw wrote:
Bogget
Glad to make you laugh we aim to pleaseg0oiw wrote:Tee, hee, PMSL, LOL, chuckle chuckle etc!
What's with irony what was noted? That the ctcss was 82.5hz and "pirate" repeater! "never" we would never condone such a thing!
Oh we're you able to access
- radiosification
Whats the status of the repeater now? Have you moved it yet, and am I correct in thinking it was being put on channel 6 too?
Repeater status:
Is currently off air until further notice due to building bits into the box, it's abit
Of a slow process as only been able to do 20mins work on it every other day,
Most of the holes in the box have drilled, a fixed mobile antenna has been attached to the top so it will not have any gain unfortunately as this was the easiest option,
I now found I running out of space for the lead acid battery to be installed,so another housing for the battery must been sourced! When I get another day free the transceiver, repeater unit, power controller will be fixed into place and then hopefully be wired up. That's most of the hard work done. Once all done it will soap tested running on the lead acid with the solar panel to see if it charges it ok.
Don't want to state a day it will be done but Iam slowly working on it.
Oh and final frez/ ctcss are not confirmed as some has stated ch6 is not great so may end up leaving it on ch7. Final details to be will be added after tests.
If it was me i would set it up about spring time as where coming into the winter now but is been quite a laugh when it was setted up, this man come on and said something was repeating him and i was like and he called radiosification "Big ben" and he can call him "Pettle" hahaRG8mini wrote:Is currently off air until further notice due to building bits into the box, it's abit
so radiosification go on the 2 meter (145.550) band and say "hello pettle" - http://www.ustream.tv/recorded/17509683 but what repeater is 145.550 on? look on ukrepeater but nothing. :/
- radiosification
What!? I didn't go on the 2m band and say hello petal. I would never transmit on amateur frequencies which I'm not licensed for.francisuk22 wrote:If it was me i would set it up about spring time as where coming into the winter now but is been quite a laugh when it was setted up, this man come on and said something was repeating him and i was like and he called radiosification "Big ben" and he can call him "Pettle" hahaRG8mini wrote:Is currently off air until further notice due to building bits into the box, it's abit
I did try calling him again on pmr446 channel 8 though.
so radiosification go on the 2 meter (145.550) band and say "hello pettle"radiosification wrote:What!? I didn't go on the 2m band and say hello petal. I would never transmit on amateur frequencies which I'm not licensed for.
where did that mention you was on the 2m band? lol
Did you try 7 aswell?radiosification wrote:I did try calling him again on pmr446 channel 8 though.
Also i had the CTCSS 82.5 when i was talking to him and also he was talking to someone called Mike aswell on the same channel
- radiosification
Here is a link for everyone to my newest video showing the simplex repeater in use:
http://youtu.be/VTRizAhBFuQ
