Rf power amp testing
Blackolive
Call Sign: G4WCS
Post by Blackolive » 26 Apr 2019, 12:58
Picked up an 140 watt 2M linear for silly money.
It was advertised as non working.
I know that the transistors can be tested with a multimeter and measuring across the junctions, but due its method of construction its not going to be easy without possibly damaging the Unelco caps.
If they have failed, do they normally fail open or short circuit ? Im hoping I can do initial testing around the RF circuitry by firstly checking the resistors particularly around the biasing circuits, then putting it on a current limited supply and measuring the voltages at various points.
Blackolive
Call Sign: G4WCS
Re: Rf power amp testing
Post by Blackolive » 26 Apr 2019, 12:59
Pics
Blackolive
Call Sign: G4WCS
Post by Blackolive » 26 Apr 2019, 13:00
Made a start on the cosmetic side
dt307
Call Sign: 163dt307
Post by dt307 » 26 Apr 2019, 15:13
i norm fit swr meter before and after if it goes off the scale the trannies are bad and i remove them and check them with a tester not a dvm .
163dt307-chris
― Albert Einstein
Blackolive
Call Sign: G4WCS
Post by Blackolive » 29 Apr 2019, 10:34
good shout
Blackolive
Call Sign: G4WCS
Post by Blackolive » 05 May 2019, 13:15
Nothing is screaming popped transistors (yet) so Ive tidied it up, changed some drifted components and caps, and got rid of all the old flux residue.
Blackolive
Call Sign: G4WCS
Post by Blackolive » 17 May 2019, 08:32
It lives.
Not tried it at full power yet as I hadnt put thermal compound on the transistors. Ive fitted a small computer fan as some of the parts inside that get warm arent heatsinked. Tidy job. Going to use it with an IC-251 with mutek front end, should be a decent station
https://youtu.be/Dy_cqqq89xI
https://youtu.be/WT7t1fq6Kc8
