YAESU FT-70 headset connector wiring
kwhunter
Call Sign: VA3
Post by kwhunter » 19 Apr 2019, 18:10
Hello.
I wonder if somebody knows how the 4 position 3.5mm connector for the headset is wired? I have an aviation headset I want to use with the handheld and short of buying a Yaesu headset and checking the wiring I have found no other information.
Thank you.
Auldgeek
Re: YAESU FT-70 headset connector wiring
Post by Auldgeek » 20 Apr 2019, 09:23
Hello,
I did a little googling and found this.
https://www.google.com/url?sa=t&source= ... HgaKp1ksjh
The official adaptor from Yaesu is a CT-44. It's used across a wide range of Yaesu HT's. Link above will download a word document that has details of the wiring for a FT-60. It should work for your FT-70
Auldgeek - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
kwhunter
Call Sign: VA3
Post by kwhunter » 20 Apr 2019, 17:08
Hi.
Thank you so much! I might have used the wrong search criteria as I didn't find that doc.
Auldgeek
Post by Auldgeek » 21 Apr 2019, 09:08
kwhunter wrote:
20 Apr 2019, 17:08
Hi.
You're welcome.
I searched for CT-44 schematic, as I figured someone would have worked out how the adaptor was wired. :thumbup:
Auldgeek - Drew
14CS06
Post by 14CS06 » 21 Apr 2019, 10:06
Hello
Here
