Wire inverted V materials ?
knobby
Post by knobby » 06 Jul 2017, 16:58
Hi all,
going to make a 90 degree inverted V from twin and earth cable, should I use the blue wire for the centre coax side and the brown for the braid side ?
Only kidding ! but will it work best with the copper bare or with the insulator left on ?
It will be indoors in the loft.
Thanks for the great forum
Call Sign: n0call
Re: Wire inverted V materials ?
Post by ch25 » 06 Jul 2017, 17:04
Bare copper solid wire.
knobby
Post by knobby » 06 Jul 2017, 18:26
:D Looks like I've got a lot of stripping to do
NightProwler
Call Sign: 163TM186
Post by NightProwler » 06 Jul 2017, 19:51
Just use the blue and brown wires as they are. I done the same in my attic and worked all over Europe on 15 watts with it :thumbup:
Kaliphan
Call Sign: M0
Post by Kaliphan » 07 Jul 2017, 16:04
ch25 wrote:Bare copper solid wire.
Why?
knobby
Post by knobby » 07 Jul 2017, 19:08
Cheers chaps, seems to be ok either way ?
Call Sign: n0call
Post by ch25 » 08 Jul 2017, 10:50
Because of skin effect. I use enamelled transfromer wire for all my wire antennas. Cheap and reliable.
26TM5890
Post by 26TM5890 » 08 Jul 2017, 19:13
excuse me, any prove of that?
Post by Admiral » 08 Jul 2017, 21:19
It depends on what you're going to use it for chap, for a simple HF RX antenna then insulated cable is absolutely fine, if you intend on sticking 10w up it then also fine, stick 400w up some 5amp insulated flex and you could burn your house down.
Call Sign: n0call
Post by ch25 » 09 Jul 2017, 12:50
26TM5890 wrote:excuse me, any prove of that?
Plenty in antenna design books.
Kaliphan
Call Sign: M0
Post by Kaliphan » 10 Jul 2017, 13:27
ch25 wrote:Because of skin effect. I use enamelled transfromer wire for all my wire antennas. Cheap and reliable.
Oh right, I was always told that was an old wives tale and it had almost no measurable effect at all unless it was over an eighth of a wavelength thick, a bit over 2 metres diameter at CB frequencies.
If you've got a proper reference that says different I'd love to see it.
26TM5890
Post by 26TM5890 » 10 Jul 2017, 17:45
Oh dear what a knowledge... Sure you are going to drive 400 watts on a thin wire in the loft..
Sam P
Call Sign: 26DR340
Post by Sam P » 10 Jul 2017, 18:47
In fairness, mate, if it wasn't for skin effect the T2LT antenna (as an example) just wouldn't work.
However I can't see why skin effect has got anything to do with insulated wire.... it's the conductor that we're interested in.
Every tactical and operational wire dipole system I've used (and that's a fair few) has had insulated wire.
Ubique Loquimur
Call Sign: n0call
Post by ch25 » 10 Jul 2017, 20:00
Millions of flies eat $hit, it does not mean it is correct.
Sam P
Call Sign: 26DR340
Post by Sam P » 10 Jul 2017, 20:16
ch25 wrote:Millions of flies eat $hit, it does not mean it is correct.
It's entirely correct, if you're a fly.
Ubique Loquimur
