how do I bodge a BNC antenna
teddyt
Post by teddyt » 22 Apr 2017, 12:00
Hope this is in the right place.
I picked up a realistic base scanner today but it has no antenna (so seems deaf) before I go and order a new one how can I test to see if it works
can I just use a bit of wire etc???
Baofeng UV82, Standard c5200ed, Icom lc-ft1610, Realistic pro-26, Trio 9r-59ds, Yeasu frdx 400, Realistic pro-2004, Yeasu ft-767gx and has the 2m, 70cms and 6m modules fitted, Yaesu FT 980,KT-8900d Quad Band, Trio,Baofeng GT-3tp, TYT MD380, Yaesu FT450D
Tigersaw
Call Sign: GW6RRL
Re: how do I bodge a BNC antenna
Post by Tigersaw » 22 Apr 2017, 12:08
yes, just poke a piece of wire a couple of feet long into the centre hole.
Post by Admiral » 22 Apr 2017, 20:07
A lot of them also have a (missing) screw-in telescopic antenna, if there's a hole on the top towards the rear then you can poke a wire down there too.
teddyt
Post by teddyt » 23 Apr 2017, 20:51
thanks chaps.. did the old wire in the back trick and it works a treat!!! so not to bad for a tenner!!!
and have just ordered a Centre Loaded BNC Telescopic Antenna from fleabay
