10 mt flag pole
WARLOCK
Call Sign: 26TM134
10 mt flag pole
Post by WARLOCK » 14 Apr 2017, 15:49
can anyone please recommend a a good STRONG 10 mt fibraglass pole to mount a antenna on .
Tim
Call Sign: 26AT239
Re: 10 mt flag pole
Post by Tim » 14 Apr 2017, 20:50
Depends on the antenna you want to mount. If it's heavier than a wire or coax antenna you'll need something like a sailboard mast, if it's a light wire or coax antenna then a put-in or telescopic Roach pole from your local fishing gear shop will do the job and is more portable if you want to get out and about with the radio.
