1st stupid question!!!
teddyt
Post by teddyt » 06 Apr 2017, 18:46
Guy's I have just picked up a Standard C5200ed duel channel mobile rig.
All seems like it works as it should but before I rush out and buy a good aerial, is there a (very) cheap way of testing it works rx/tx not looking for reach just to see if it does the job?? I have a boefang uv 82 with which to test it .
so any ideas .... long length of wire etc????
Oh and be gentle with me I'm new :oops:
Baofeng UV82, Standard c5200ed, Icom lc-ft1610, Realistic pro-26, Trio 9r-59ds, Yeasu frdx 400, Realistic pro-2004, Yeasu ft-767gx and has the 2m, 70cms and 6m modules fitted, Yaesu FT 980,KT-8900d Quad Band, Trio,Baofeng GT-3tp, TYT MD380, Yaesu FT450D
nay27uk
Re: 1st stupid question!!!
Post by nay27uk » 07 Apr 2017, 21:15
Dummy load for TX and just a bit of wire for RX with your uv 82 quite close to it, however this will not test the radio over any distance and the only way of telling if it is any good on distant TX/RX is to use an antenna
M6LIG / 2E0LIG / 26TM1995
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
Call Sign: G4RMT
Post by paulears » 07 Apr 2017, 21:23
Stuff 19" of any old wire (or even a coat hanger if it's not painted, into your aerial socket and that will work for 2m and 70. Probably best on low power of course - At a push, I've even used solder! Fine for a quick one two check.
teddyt
Post by teddyt » 07 Apr 2017, 22:07
Thanks guys... but iI picked up a Diamond X-300 Home base antenna today for £20.
so I think I'll try that :)
nay27uk
Post by nay27uk » 08 Apr 2017, 22:50
yepo that would be your best bet teddy.
Interesting looking radio by the way
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
kilimax
Call Sign: GM0BRJ
Post by kilimax » 10 Apr 2017, 16:53
Brings back memories. The one and only Standard radio I owned was its successor, the C5608D. It was an excellent radio and I used it mobile for a few years.
Good luck and enjoy using it.
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Post by Admiral » 10 Apr 2017, 20:54
Crikey, that is a blast from the past, the D version is obviously the 50 watt flavour, so don't be transmitting for too long with a mismatch. Sadly because of it's age it will be a bit limited these days, just a 1750hz tone and 25Kc steps, so not too useful for repeaters unless you are very lucky with your local one being on a 25Kc jump and having legacy 1750hz capability, or a whistle. The audio output is very strong from these sets and I know of a few that were converted to VHF marine band as they could be heard over the noise of general sea conditions and the 50w output was very welcome when bobbing about on the shores.
