Modulator / Scarlet Warrior Dipole Antenna
bigfella
Post by bigfella » 21 Aug 2016, 20:17
Thinking of a low key antenna for 10-11m use.
Was thinking of using 2x mobile antennas such as Modulators or Scarlet Warriors on a 3/8 dipole mount, mounted above the roofline vertically polarised.
Has anyone tried this antenna setup, were the results any good?
andrew013
Call Sign: 26AT013
Re: Modulator / Scarlet Warrior Dipole Antenna
Post by andrew013 » 22 Aug 2016, 14:40
i used two quad wire wound mobile ants by solarcon i think but i used them horizontal worked ok ish i also used 2 dv 27s did work but quite poor it was more for mobile use to have a vert and horizontal but then i thought if im going to use a dipole for mobile i may as well get a 4 ele beam to go mobile with so now i take an imax 2000 and or the 4ele for mobile or a 1/4 wave whip for the car as well
i never did try scarlet warriors as the quad wire ants broke the mount with their weight :(
bigfella
Post by bigfella » 23 Aug 2016, 15:27
Thanks for the advice, I thought they might make a good "off the shelf" solution that would be visually neat and tidy and more to the point, fairly low key.
Dragonfly
Call Sign: 26TM363
Post by Dragonfly » 23 Aug 2016, 22:13
If they worked ok everyone would have one ,There is the Excalliber antenas but they are also lame . The Watpole made from a halfbreed and a Quarterwave ground was the old favorite . Wire dipole or GP in the loft is usually as good as it gets for a stealth antenna .
jason
Call Sign: 26TM070
Post by jason » 29 Aug 2016, 00:43
Now i had a watpole about 1981 . Did ok for what it was . Cheers for bringing back the memory :-)
bigfella
Post by bigfella » 29 Aug 2016, 06:40
Haha, no worries!
