Just a theory Antennas
StormShadow
Post by StormShadow » 20 Apr 2016, 09:06
So you'd have a UHF dipole now compare that with a 40 meter dipole? I'm talking about the thickness of the elements so for example a 70cms dipole is small with thicker elements that you'd have a 40 meter dipole antenna with thin elements... Now this is my theory, having a chunky 40 meter dipole with thick elements, I'm talking at least 2 foot thick elements this will have better performance that a standard wire dipole right?
Re: Just a theory Antennas
Post by Admiral » 20 Apr 2016, 09:12
A 40m dipole with 2ft thick elements? You'd need a leccy pylon to keep it in the air.
As you're talking theory, then the performance shouldn't be any better than a wire dipole at the same height, but the advantage would be that you could probably put 500kw through it whereas the wire would burn up at around 1kw.
StormShadow
Post by StormShadow » 22 Apr 2016, 21:50
Its interesting tho. I made a 2 meter wire dipole when I was first licensed from speaker wire and performed crap. I then tried thicker wire and the performance improved, then when I made a dipole from copper pipe later on that worked even better so I reckon the thickness has some part to play in the performance.
StormShadow
Post by StormShadow » 23 Apr 2016, 00:51
Somebody please tell me that my theory is wrong in regards to thickness of antennas having more performance? I need a few more opinion's to put my mind at rest
2E1IIP
Post by 2E1IIP » 23 Apr 2016, 15:10
RF travels on the outside (surface skin effect) of the conductor, like any AC voltage however a larger diameter will give a slightly wider bandwidth.
dt307
Call Sign: 163dt307
Post by dt307 » 23 Apr 2016, 15:54
as above the only advantages of thicker elements is
more bandwidth
more power handling
can be made to be self supporting ie 10m dipole
163dt307-chris
― Albert Einstein
theEarwigger
Call Sign: M0RZF
Post by theEarwigger » 15 May 2016, 14:56
A practical "thicker elements" antenna is here:
http://www.tc2m.info/TC2M%20HF%20Vertical%20G8JNJ.pdf
