frequency counter
dt307
Call Sign: 163dt307
frequency counter
Post by dt307 » 13 Mar 2016, 14:05
Got a china plj-8led counter
Sunday morning project
Maplin box
Bnc socket
Power switch
Pp3 cable
Made up a probe lead as well
Turned out great
163dt307-chris
― Albert Einstein
ROTEL240
Re: frequency counter
Post by ROTEL240 » 13 Mar 2016, 20:17
Will this work on ssb or does it need a constant carrier?
GeeFull
Post by GeeFull » 14 Mar 2016, 08:18
Reading its specs on one of the E-Bay sites offering it:
As it stands as a simple RF sampling counter it would require a constant carrier.
Useful as stand alone simple bit of RF sniffing, frequency displaying, test equipment.
It "appears" to possibly have the option for an IF offset to be programmed?, although its not worded that clear in the advert so check with seller first!
Maybe the OP who's built one up can confirm if it does have IF "offset" facility?
By using that IF offset mode, if indeed its available, and coupling to the correct point in say a CB transceivers frequency derived mixing stages, it could be used to display the frequency the radio channel is set at, like many of the made for the job counters that are around.
In that case, wired to the correct RF sampling point, it will display the radios set channel frequency.
Either way it doesn't seem a bad little bit of kit for the money!
http://www.ebay.com/itm/DIY-blue-PLJ-8L ... 2041571187
http://www.ebay.com/itm/DIY-red-PLJ-8LE ... =undefined
http://www.ebay.com/itm/DIY-green-PLJ-8 ... =undefined
kr0ne
Post by kr0ne » 14 Mar 2016, 12:05
I've got one that I also shoved in a box with a BNC and a PSU. Only cost about £3 on the slow boat from China...
If there is a way to set an offset, it wasn't obvious - although I think there was an ICSP header on the board so hacking the uC might be a possibility.
dt307
Call Sign: 163dt307
Post by dt307 » 15 Mar 2016, 20:43
As been said it is ok for a simple counter
For setting the offsets on ssb radios ie 16.420 ect ect when connected to the correct test points
Or you can loosely couple to the tx strip and read am,fm directly.
It does have an if offset plus or minus
So you could say use it for a 148/360 ect
BUT it has one offset and its on or off by menu
For most rigs you would need the counter to the correct offset for am then have two more switched in for the usb lsb so the counter reads right on all modes
This counter don't support that like the one I installed in the Madison or the add on ss3900 ones
Just for checking frequency if offsets ect its great
163dt307-chris
― Albert Einstein
