Radio facsia decals
sparky7083
Radio facsia decals
Post by sparky7083 » 01 Jun 2015, 20:20
hi ya guys
I have several radios that have worn decals ...ie Volume, tone squealch transferes etc...
Is there anyone who sells new decals ???
regards
Daz AkA sparky
Trog
Re: Radio facsia decals
Post by Trog » 01 Jun 2015, 20:58
I once re-labelled a CB fascia with individual letter transfers as the rig had been 'changed' (it took ages). The lettering didn't last though as it wasn't as resilient as the original wording. Might be best to spray the finished fascia with clear matte varnish or lacquer to protect the lettering (that's assuming you're stripping the rig down).
Not sure if you can get whole words such as volume and squelch etc. If you can it would be from the States or Europe and not likely to be from this country.
Trog
Post by Trog » 01 Jun 2015, 21:03
This page from another forum might interest you.
http://s3.zetaboards.com/copythat/topic/7488691/1/
Irishman1127
Moderator
Moderator
Call Sign: EI7KO
Post by Irishman1127 » 01 Jun 2015, 21:03
Www . Gammaray graphics.com
He does all my decals. Even one off stuff once you send him out the original so as he can scan it
CQ CQ CQ DX
steve13d
Call Sign: 26CM1302
Post by steve13d » 17 Jun 2015, 10:52
I've done it with old record players and radios by printing them off in "mirror image" onto transfer paper with a laser printer and then iron them onto the right position once you have the sizing right. Much in the same way of producing pcb's. It looks that bit better than stickers and water slide decals, especially once you have gotten the hang of it
****26-TM-1302****26-CM-1302****
theteam2015
Call Sign: 42
Post by theteam2015 » 22 Jul 2015, 06:38
thank you to much
Dragonfly
Call Sign: 26TM363
Post by Dragonfly » 22 Jul 2015, 10:51
Hope you do it better than this Midland i picked up .
29 RSN 669
Call Sign: 29RSN669
Post by 29 RSN 669 » 01 Sep 2015, 13:03
hi Sparky
using a laser printer if you reverse print the text onto light paper(turn the print density up to max) then place over where you want it
then steal some of your wife's acetone nail varnish remover and wet the back side of the paper it will transfer the print onto the surface
be careful some plastics don't like acetone test it first on something else !
its quick and dirty but it works
regards
john
29 RSN 669
29 RSN 669
Call Sign: 29RSN669
Post by 29 RSN 669 » 01 Sep 2015, 13:06
forgot to say you need to rub the paper away it wont just peel off
Techquest
Call Sign: 29VLF125
Post by Techquest » 01 Sep 2015, 17:02
Acetone will bleach the pigment out of plastic better to use chloroform
Techquest AKA Jedi
Av101 Astro Plane Old Imax n Loads of Radios
Mmmmmmmmmmm ADAMS n other Presidents
andymuza
Post by andymuza » 01 Sep 2015, 18:11
Irishman1127 wrote:Www . Gammaray graphics.com
Seconded, I have used these and they are fantastic, cheap and excellent quality.
Irishman1127
Moderator
Moderator
Call Sign: EI7KO
Post by Irishman1127 » 01 Sep 2015, 21:31
The guy does excellent work. Can't recommend him enough.
CQ CQ CQ DX
prettypolly
Call Sign: 26FB185
Post by prettypolly » 01 Sep 2015, 21:47
chloroform causes cancer
Mattylad
Call Sign: RDX64
Post by Mattylad » 01 Sep 2015, 22:29
Techquest wrote:Acetone will bleach the pigment out of plastic better to use chloroform
And you keep falling asleep when doing it :)
Irishman1127
Moderator
Moderator
Call Sign: EI7KO
Post by Irishman1127 » 02 Sep 2015, 18:52
Not if your a Jedi like Ray is.....
CQ CQ CQ DX
