Another project
- Call Sign: M3YCM
Another project
Hello everyone,
I was on he a while ago and made a 12v psu from a pc power supply well im now on it again only i want to make one in a big case, im going to put it in an old 2u pc case i have and this time im going to make 2 of them to make 24v like this http://hildstrom.com/projects/atxbenchp ... index.html
Only i want 13.8v so how could i make this veriable ?
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
“Those most hopelessly enslaved are those who falsely believe they are free” Johann Wolfgang Von Goethe
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
- Call Sign: M3YCM
Re: Another project
Or could i put in a voltage regulator?
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
- cjay
- Call Sign: cjay
Re: Another project
It'd be better to work out how to mod the PSU to bring the 12V rail up to 13.8V than waste all that energy as heat (unless you were going to use a switching regulator)hdjmings1 wrote:Or could i put in a voltage regulator?
- Call Sign: M3YCM
Re: Another project
cjay wrote:It'd be better to work out how to mod the PSU to bring the 12V rail up to 13.8V than waste all that energy as heat (unless you were going to use a switching regulator)hdjmings1 wrote:Or could i put in a voltage regulator?
Well ive just found a youtube clip https://m.youtube.com/watch?v=mK_rIs7uFlo But didnt know if i had the knolage to do that
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
- Call Sign: M3YCM
Re: Another project
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
- kr0ne
Re: Another project
OK, I'll be the first to say: If you are unsure whether you have the knowledge or experience to modify a mains PSU then DON'T FREAKING DO IT!!!!!!!!!!!!hdjmings1 wrote:Well ive just found a youtube clip https://m.youtube.com/watch?v=mK_rIs7uFlo But didnt know if i had the knolage to do that
Seriously, I don't mean to discourage you from experimenting and learning about electronics but if you have to ask the above then you really shouldn't be messing around with the insides of a mains powered switch mode PSU. Even if you manage not to kill yourself or your gear, spare a thought anyone else who may unwittingly fire it up one day when you are not around...
- Call Sign: M3YCM
Re: Another project
kr0ne wrote:OK, I'll be the first to say: If you are unsure whether you have the knowledge or experience to modify a mains PSU then DON'T FREAKING DO IT!!!!!!!!!!!!hdjmings1 wrote:Well ive just found a youtube clip https://m.youtube.com/watch?v=mK_rIs7uFlo But didnt know if i had the knolage to do that
I have a standered knolage of electronics but not lots like some on here which is why i asked some help
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
- cjay
- Call Sign: cjay
Re: Another project
Actually, after consideration, I'm with kr0ne on this, a switcher PSU is a dangerous piece of kit, that video shows an idiot, the filter caps he shorts out carry in the region of 180V DC each and can be deadly. Seriously, it's not a piece of tech to learn electronics on unless you're supervised and have a proper, safe workbench.hdjmings1 wrote:kr0ne wrote:OK, I'll be the first to say: If you are unsure whether you have the knowledge or experience to modify a mains PSU then DON'T FREAKING DO IT!!!!!!!!!!!!hdjmings1 wrote:Well ive just found a youtube clip https://m.youtube.com/watch?v=mK_rIs7uFlo But didnt know if i had the knolage to do that
- Call Sign: M3YCM
Re: Another project
thanks for the input
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
- kr0ne
Re: Another project
Yeah, re-purposing a computer PSU is one thing but it's really not a good idea to start messing about trying to modify the circuit if you are not sure what you are doing...
What are you planning to power with the PSU? What sort of current do you need and are you looking for a fixed voltage at 13.8V or something you can vary as required?
- Call Sign: M3YCM
Re: Another project
that was why i said i found the vid but didnt think to do it as i dont think i can,kr0ne wrote:Yeah, re-purposing a computer PSU is one thing but it's really not a good idea to start messing about trying to modify the circuit if you are not sure what you are doing...
the psu will power a radio so hi current is needed, and as for voltage i suppose it not really important but would like around 13.8/14v
26-TM-1982
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
M3YCM
President Lincoln
RM KL400
siro HI-POWER 4000
