mobile taxi antenna ideas
- Call Sign: M7LMH
Ok guys looking for ideas. My dads retired from the taxis and this was the antenna he was using on the car. http://www.sharman-multicom.co.uk/SHARM ... tml?last=8. It states the antenna covers 164-174 MHz. Unfortunately the radio was rented just wondering if theres anything i can do with it regarding 2m/70cms (recieve only). iv got a dual bander vertical on the roof but seems to be lacking in performance so was thinking of doing an experiment. any help or suggestions welcome and greatful
- Banned
Re: mobile taxi antenna ideas
It should work OK as it is. Needs a ground plane to work against though.
- Dragonfly
- Call Sign: 26TM363
If its just for recieveing you could turn it into a discone by adding different lengths of wire nipped under the antenna thread , PMR 446 is around 5 and a half inches . The more different lengths of wire you add the more resonant frequencies you will get . An old wire coat hanger would be ideal if you don't have any spare whips to cut up .
http://www.bing.com/images/search?q=Out ... dIndex=142
- bigpimp347
cut it around 18" long,
1/4 wave on 2mtrs and 3/4 wave on 70cms
and Dragonfly, that's nothing like a discone, that's just two radiators off one feed..
search what a discone is..
- Andy
It's a nest of monopoles! Or it would be if it had a few more poles Bigpimps suggestion is probably the best. The 70cms polar response will be upward-tilting, but it'll work.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- Call Sign: M7LMH
thanx guys. as tempting as ADMIRAL's idea of buying a taxi is i decided to go for the cheaper option & use BIGPIMP347's idea. hoping to mount it on the roof this weekend at some point so will let you guys know how it goes! as i have a few old mobile cb whip antennas that no longer get used my next experiment will be a pmr446 antenna. might knock it up b4 goin on roof so i can mount them both at the same time cheers again guys
