PLT Device Schematic
2E1IIP
Post by 2E1IIP »
Chaps, I am looking for a schematic diagram for a PLT networking device, tried several google searches without success - any ideas?
cjay
Call Sign: cjay
Re: PLT Device Schematic
Post by cjay »
PROLIANT wrote:Chaps, I am looking for a schematic diagram for a PLT networking device, tried several google searches without success - any ideas?
You're probably going to have to sign a heavy duty NDA to get one of those but there may be a way 'round that. If you can find an FCC approval number you might well find the schematic on the FCC website.
2E1IIP
Post by 2E1IIP »
Really? Must be some other way, I have a BT unit that I am dissecting at the weekend see what info that gives up.
cjay
Call Sign: cjay
Post by cjay »
PROLIANT wrote:Really? Must be some other way, I have a BT unit that I am dissecting at the weekend see what info that gives up.
There's a few teardowns on the 'net that will give you the basic chipset details from which you may be able to find a datasheet with a typical application in it, that should give you the essentials.
I gave up looking. Personally, I'd go the FCC route but I think that PLTs are proprietary between brands, I.E. unless they use the same chipset then you're not going to get them to play nicely together. Hence what you learn about one brand won't necessarily give you the information you need about the others.
2E1IIP
Post by 2E1IIP »
What I am more interested in is the mains coupling, not yet seeing inside the device I would hazard a guess that it would be some form of isolation barrier with opto-couplers.
crusty
Post by crusty »
Suspect it''l employ a proprietary chip something akin to the ADuM4160 used for high speed USB isolation with a stepped input. Good luck with the research.
2E1IIP
Post by 2E1IIP »
Thanks for the info so far guys.
cjay
Call Sign: cjay
Post by cjay »
PROLIANT wrote:What I am more interested in is the mains coupling, not yet seeing inside the device I would hazard a guess that it would be some form of isolation barrier with opto-couplers.
I think it's usually a transformer characterised for the spectrum used. Worth bearing in mind that it's highly likely the device will be at mains potential all the way up to the ethernet magnetics, I.E. very dangerous.
Mattylad
Call Sign: RDX64
Post by Mattylad »
Can I ask why?
Surely you don't want to build one yourself?
Might as well just pick up your radios and throw them in the bin if so :)
2E1IIP
Post by 2E1IIP »
Mattylad wrote:Can I ask why?
Gosh no, couple of reasons:
I am looking for a way to better filter either the unit itself or design a method of externally filtering the QRM from the device to other radio equipment.
Failing the latter then having better understood the technology, find a way to disrupt the operation of the device.
Mattylad
Call Sign: RDX64
Post by Mattylad »
Top idea.
If I find anything I'll pass it on. (assuming I'm not under an NDA for it).
2E1IIP
Post by 2E1IIP »
Mattylad wrote:Top idea.
Cheers, that would be great.
EARSEGPK
Call Sign: PK303
Post by EARSEGPK »
Hi there, If you are attempting to filter PLT/PLC device signals have a look at http://www.audioscientific.com/Circuits ... ls_100.htm scroll down to Circuit 43 - Passive filter cleans up power-line communications.
This provides info on frequency and bandwidths used on early PLT/PLC devices. There are two images, one of which includes a basic circuit diagram. May help to get you going..
http://www.ukqrm.org.uk/ also have info and links relating to regulation and use of PLT/PLC devices.
Possibly the best place for technical discussions on PLT/PLC devices can be found on the forum at http://www.interference.org.uk/forum/
Hope that helps. :-)
- Personally the last PLT/PLC device I got hold of were immediately scrapped for parts. Wiped out most HF and caused nasties all over Air and Marine VHF bands.
The quieter we become, the more we can hear..
2E1IIP
Post by 2E1IIP »
EARSEGPK wrote:Hi there, If you are attempting to filter PLT/PLC device signals have a look at http://www.audioscientific.com/Circuits ... ls_100.htm scroll down to Circuit 43 - Passive filter cleans up power-line communications.
Cheers for the info, seems my neighbors are having a PLT fest at the moment...
cjay
Call Sign: cjay
Post by cjay »
So if you can't filter the noise out you'll be creating even more RF hash.
Nice.
Last time I checked, deliberately causing interference like that was illegal.
Well done you.
