swr meter
- Call Sign: 108tm
Re: swr meter
double whoosh
- cjay
- Call Sign: cjay
Re: swr meter
heheh, basically a single needle single meter SWR/Power meter like the TM999 doesn;t have enough circuitry to drive two needles or two meters, all the switched on the front are there to route the right bits of circuit to the meter depending which function you want to use.tomaka00000 wrote:double whoosh
So converting it to dual needles or two meters would need you to add circuitry.
And recalibrate it.
And probably re-draw the scale on the front of the meter to match the output of the circuit.
So, yeah, it's possible but more of a pain in the butt than it's worth.
- Call Sign: 108tm
Re: swr meter
its not for the tm999 any hoy is my tm999 doing
