Hi all,
I did a bit of skip rummaging at work and pulled out an old Metcal mx500 solder station, including a load of tips, stand, PSU box and hand piece. When I plug the hand piece into the PSU the orange light comes on, I believe this indicates some form of fault. Does anybody on here have the same station and would be willing to test the hand piece for me? Theres no point searching for a new hand piece if the PSU box is dead.
Cheers
Metcal solder station
- George EI7KO
- Call Sign: EI7KO
Re: Metcal solder station
Id reckon the element has gone in the hand piece. They can be got without too much hassle I think...
BLUE LED'S ARE BEST!!!!
FACEBALLS GROUP: https://www.facebook.com/groups/irishcustomradios
YOUTUBE CHANNEL: https://www.youtube.com/channel/UC4aXkT ... wszD8E68Dg
- Call Sign: 29VLF125
Hi JonC
theres the link for the manual for it
just had a quick look at it says amber light means ground break
check it out
nice station BTW cool if you can get it sorted
check it out
Techquest AKA Jedi
misssed the linkTechquest wrote:Hi JonC
check it out
theres the manual for it
Techquest AKA Jedi
