Hi all,
I was off to a good start, and now I'm not lol
I've made an inverted V dipole posisioned it in the loft and tuned it, and now today the SWR has gone off the chart, I've been told this could be down to a short, open, or lack of ground. I've checked all the connections by eye (multimeter is dead) and everything seems fine. Seeing as it doesn't have a ground and was ok yesterday I'm assuming its got something to do with that.
How do I actually ground the antenna? I don't have a ground spike so could it be ground by wiring to a mains plug ground? Where on the antenna or radio-antenna coax should the ground wire be connected?
Many thanks
Grounding a dipole
Re: Grounding a dipole
Dipoles don't need a ground they are a balanced antenna.
Check coax/pl plugs.
NEVER WIRE AN ANTENNA TO THE MAINS!
Build a man a fire, he'll be warm for a night. Set a man on fire and he'll be warm for the rest of his life.
- Call Sign: DP584
ok thanks. Could a poorly insulated leg end cause the same result?
- Anthony123
- Call Sign: Gw0
I would suspect either the connections or the coax... As its been said you dont need a ground with a dipole... The dipole is a balanced antenna.. There not really meant to be grounded...
