Drive on plate
Drive on plate
Have made a drive on base which consist's of a cast iron base off a patio set (what the parasol goes into) which is ideal for a pole,which is a pole off security fencing(heras)which is fastened with rope onto a 2 wheel sack barrow that I have removed the wheel's,and it can lay flat on it's back so you can drive over it with the motor to stop any movement.The width of the hole on the base is ideal for a length of heras fencing,the stuff you get around building sites to slide into,and I have added another shorter pole at the top with the bracket's/clip's,so that the A-99 can slide inside and it is great for connecting the coax aswell,just slide the coax through the top pole,and connect onto the antenna,then slide the A-99 into the top pole.I have put a couple of heavy duty steel jubilee clip's about 1inch/25mm down from the black plastic that the tuning ring's sit on,to keep the ring's an acceptable distance away from the steel pole.It has worked very well and has cost next to nothing to make,but you could use about any homebase antenna,but the A-99 is a good fit inside the heras fencing,hope this help's someone looking for an easy to make drive on plate.
27.555 Usb
27.555 Usb
- bigpimp347
Re: Drive on plate
just seen one on facecrap a guy used an axle stand two lengths of angle and a bar,
welded a pipe into the axle stand..
looked ok..
after all £30 to £50 for something you can make for £10..DIY...why not..!!
looked ok..
- Black_Pirate
- Call Sign: 26TM034
Re: Drive on plate
PIC please.....
You show me yours and I,ll show you mine
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
Re: Drive on plate
Will get a pic up at the weekend Black Pirate,the next time I am out n about dxing.
27.555 Usb
27.555 Usb
- sureshot
- Call Sign: 26TM413
- bandit
Re: Drive on plate
Here you go mr skyscraper
you might be able to work the world but a pc is a different story
- bandit
Re: Drive on plate
And some more ....
- George EI7KO
- Call Sign: EI7KO
Re: Drive on plate
Nice job
BLUE LED'S ARE BEST!!!!
FACEBALLS GROUP: https://www.facebook.com/groups/irishcustomradios
YOUTUBE CHANNEL: https://www.youtube.com/channel/UC4aXkT ... wszD8E68Dg
Re: Drive on plate
And the hose reel is perfect for storing the rg213 coax,thank you Mr Bandit for the upload's,well appreciated
27.555 Usb
27.555 Usb
- New User
Re: Drive on plate
this is my set up just slipped on to the tow bar on my landcruiser sirio gain master on scaffold pole with tilt over, ideal for talking to the mac lads and st helens massive from my perch
Re: Drive on plate
Have a look at car sales forecourts, they use a similar type to advertise
