loop ant? ?
Black_Pirate
Call Sign: 26TM034
Re: loop ant? ?
Post by Black_Pirate »
yes I was well impressed....also I think the noise has either gone or been reduced by 80/90 %....
can't wait to try it against a vertical side by side...metaphorically....
the receive on other bands is great too....the "local 6 metre repeater " is 40+
and if I had used black shelf brackets it would have been low profile....
apart from the size which I can maybe trim.......making it more of a diamond shape
(great to experiment)
can,t think of a down side.......
don,t think I ,ll ever get a Qsk from Oz again on 12/15 watts ...
I will post some photos shortly... I,m making a lighter ...portable...."Bambi" type
with a nice set of carp poles now I know it works well...
thanks for the post....
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db..... 😊 See FB page...
26T.M.034
GOOD LUCK IN DX
Eddythealien
Re: loop ant? ?
Post by Eddythealien »
Hi
I must admit I made a loop antenna for 17m a few weeks back and had it in the worst place possible 1m from the ground at base against the side of my house and instantly on 4w while trying to trim it to right length had a QSO into Croatia on psk31. Haven.t had a chance yet but want to hoist it up a 12m pole in open space and see what it does with decent propagation. Only went for 17m cos that about the length of the wire I had liing around. Used a 4:1 balun.
regards
Eddy
Yaesu FRG-100
Yaesu VR-5000
Yaesu FRG-7700
Yaesu FRG-7000
Icom FRG-100
Icom IC-718
Icom IC-706 Mk1
Icom PCR-100
President Jackson
MJ6BDJ, 2J0COQ & MJ0LEL
Kenwood TR-9130
Baofang UV-3R
Black_Pirate
Call Sign: 26TM034
Re: loop ant? ?
well apart from a 1/1 swr at ground level and 1.8 at 10 feet....it works a dream...
took out the metal shelf brackets now and use duct tape to firm up the cross piece could use
two thick tie wraps...!!
but solid enuf for light winds
its about a 4/6 main pop together for portable...
hope photo works
26T.M.034
GOOD LUCK IN DX
HomerBB
Re: loop ant? ?
Post by HomerBB »
It looks great and seems to be working very well for you.
To answer the question you asked early in the thread, yes, to move the low SWR point further up the band shorten the overall length of your loop.
Great Job!
Black_Pirate
Call Sign: 26TM034
Re: loop ant? ?
yup will do....cheers for that...
I,m now working on a bazooka for the next one.I have 50 ohm but I,m wondering if I can
use up the rest of my 75 ohm up needs the velocity factor of the 75 ohm for that...
I will be able to get the bazooka higher and I,m wondering if I can have 80% of the antenna
horizontal and two 10% dangling !?!?!?!
hmmmmmmm !?!
let's see..
26T.M.034
GOOD LUCK IN DX
Black_Pirate
Call Sign: 26TM034
Re: loop ant? ?
Re wired the loop yesterday with some proper
"antenna wire" 5quid for 50 meters...measured
it properly and swr was lowest at 27.245...spot
on for me as i do a little data there...
Should have a little less wind resistance for winter
and can go a little higher too 65ft to tip on max...
Sorry to any spuggies in advance
May try a different feed point at some
Point but I,m not too convinced its
necessary :roll:
26T.M.034
GOOD LUCK IN DX
Black_Pirate
Call Sign: 26TM034
Re: loop ant? ?
antenna now trimmed with antenna analyser, so looking to fit all parts
tightly and waterproof..
swr moved a little from head height to 30 ft so take note...
hoping to replace canes section with threaded tent poles...!
improving strength and lightening a few grams !!!
26T.M.034
GOOD LUCK IN DX
