this. http://www.radioshack.com/product/index ... =CT2032189
Its for an off-centre dipole that I'm building.I can't find a supplier in this God-forsaken neck of the woods.Even the 'Bay goes straight to the US,as does Amazon,so I may have to end up buying there.Cheers.
Trying to fin UK source of....
- Jon_D
- Call Sign: G4FUT
Re: Trying to fin UK source of....
For my OCFDipole, I use a 4:1 balun. this can be fed with either coax which has a common mode choke to stop the outer radiating, or ladder line.
Even if the voices on my head aren't real, they do have some pretty good ideas
Jon G4FUT
Ex-Army
RSARS 1425
Jon G4FUT
Ex-Army
RSARS 1425
- GW0DIV
- Call Sign: GW0DIV
Unless it's for RX, QRP or you really want that paricular item, I would use any of the dozens of off the shelf solutions available from the UK or wind my own 4:1 balun. I would think more than a Watt or two would flush all the "magic smoke" right out of tha balun!!
http://www.facebook.com/southwalesradio
http://www.radioclubs.net/rars/
Twitter: @GW0DIV
President of Bristol Channel Repeater Group
Twitter: @GW0DIV
I'm following this guys lead http://forums.radioreference.com/build- ... tenna.html Hes building it for his scanner,so he says.I don't really need it but I thought I'd give it a go anyway.Give me something to do.What do you guys think of it?
- crusty
I built/use the same OCF dipole. My tests showed the balun made no difference to received signals at VHF, but produced weaker signals at UHF regardless of balun winding or core material. I ditched the idea, and now use a bunch of type 73 ferrite beads on the coax close to the feedpoint. Works best as a low profile broadband antenna when mounted in the clear. HTH.
Thanx crusty.I mainly listen to airband and have just built a dedicated dipole for that purpose,using the same materials.I had a lot of copper pipe left over afterwards so rather than throw it out,I thought I'd have a go at something else.These type 73 beads you speak of,would they be any better,or worse than a 4:1 balun?
Also,if you don't mind me asking,what is 'HTH' at the end of your post?
- crusty
Hi Bassman. The ferrite beads act as a choke to reduce the chance of local interference (common mode currents) being picked up on the coax's outer conductor. They don't do any impedance transformation like a 4:1 balun, they just help keep unwanted signals out of the receiver. If you still want to experiment with using a 4:1 balun, I got the best results using a BN-61-0202 binocular core with twisted bifilar windings.
The OCF vertical dipole is handy as its resonant on it's even harmonic, and gives a double sweet-spot depending on what frequency you cut the dipole for. I cut mine for 122mhz and has a second peak response at 244mhz (one leg 42cm, the other 74cm).
