Hi, does anyone know if you are able to get a board to use in a uniden uniace 400 cb radio?
and if so where can i buy the board?
thank you
a cb freek
UK FM ON A UNIDEN 400
Re: UK FM ON A UNIDEN 400
Hi. You can get a UK40 chip which can be "piggy-backed" onto the existing mid-block one, so when switched it converts to the UK40. It can be done the other way around on a Uniden 200 UK radio, so it converts it to mid-block too. If you contact either Cubwolf or Black Spirit on here they'll sort you out one way or another. Hope that helps, Dave.
- bigpimp347
or just get a TC9119 and remove the TC9106 from the rig and make it UK40..
